Wiring HELP?! Should be simple question...
Old Jul 11, 2002
Explosivo's Avatar
The dog told me to do it
Explosivo is an unknown quantity at this point
OK... I posted this question on ICE and a day or so ago in Tech Stuff....
Anyway, I wired up my alarm, and now need to wire in the parking lights. One wire.
However, I was told that the wire ir red/black by alarm company, and red/yellow by the DIY. Both say this wire is by the fuse box.
There are like 2 or 3 diffferent wiring harnesses by the fuse box; one goes behind it, and the others go into it.
The one behind it is attached with a yellow tie. Is this where I should be looking? Didn't see any combo red wires there...
HELP!!![IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Jul 11, 2002
CrankinCivic's Avatar
CrankinCivic is an unknown quantity at this point
the positive parking light wire is by the fuse box .. it is a red and black wire ... there is also one at the factory alarm module connector which is a green plug , where you grab door trigger ... ok is anybody knew that i gave this out it might be bad for me .. so you can pout this in the DIY section if you like this is Dei's tech sheet , never had an issue with it for most cars, sometimes the have issues but ya knwo ..
YEAR: 2001 MAKE: Honda MODEL: Civic STYLE:
| ITEM | WIRE COLOR |POL | WIRE LOCATION |
| 12V |white | + |ignition harness |
| STARTER |black/white | + |ignition harness |
| IGNITION |black/yellow | + |ignition harness |
| ACCESSORY |black/red | + |ignition harness |
| SECOND ACCESSORY |white/red | + |ignition harness |
| POWER LOCK |white/blue | - |gray plug above drivers kick|
| POWER UNLOCK |white/green | - |gray plug above drivers kick|
| LOCK MOTOR |yellow/black | |back of the fusebox *3 |
| UNLOCK MOTOR |yellow/green | |back of the fusebox *3 |
| DISARM DEFEAT |yellow | |back of the fusebox *3 |
| PARKING LIGHTS + |red/black | |back of the fusebox |
| PARKING LIGHTS - |blue | |factory alarm plug *1 |
| HEADLIGHTS |blue/red | - |headlight switch |
| DOOR TRIGGER |*2 | - |factory alarm plug *1 |
| DOME SUPERVISION |comes on with unlock | | |
| TRUNK/HATCH PIN |red | - |factory alarm plug *1 |
| TACHOMETER |blue | |test connector *4 |
| SPEED SENSE |white/green | |PCM *5 |
| BRAKE WIRE |white/black | + |brake pedal switch |
| HORN TRIGGER |orange | - |steering column |
| WIPERS |blue (L), blu/yel(H) | - |steering column |
| LF WINDOW UP/DOWN |red/blk - red/yel | A |drivers window switch |
| RF WINDOW UP/DOWN |blu/red - blu/wht | A |drivers kick panel |
| LR WINDOW UP/DOWN |brn/wht - brown | A |drivers kick panel |
| RR WINDOW UP/DOWN |blu/org - brn/yel | A |drivers kick panel |
| RADIO 12V |white/red | + |radio |
| RADIO GROUND |black | - |radio |
| RADIO SWITCH |yellow/red | + |radio |
| RADIO ILLUMINATE |red/black | + |radio |
| POWER ANTENNA | | | |
| LF SPEAKER |grn/blk - lt green | |radio |
| RF SPEAKER |grn/yel - gry/red | |radio |
| LR SPEAKER |blu/wht - blu/blk | |radio |
| RR SPEAKER |pink - blu/yel | |radio |
NOTES:
NOTE: This vehicle has an immobilizer system that needs to be bypassed
when adding remote start. Use DEI part number 555U.
*1 The factory alarm plug is a green plug above the drivers kick panel.
*2 The drivers door trigger is green, front passenger door trigger is lt.
green/red, and the rear door trigger is green/white.
*3 In the top left plug.
*4 It is a 2 pin plug to the passenger side of the battery.
*5 The PCM is behind the glove box. The vss is in a connector A (31 pins),
pin 18. The vss is also blue/white at the cruise control module to the
left of the steering column.
e you grab door trigger and somethig elese
Old Jul 11, 2002
Explosivo's Avatar
Thanks Eric... I'll give it a go tomorrow and let you know how it works... Sorry if the question was dumb, but electrical is not my forte.
Old Jul 11, 2002
its cool man , my pleasure , its what i do day in and day out .... good luck ... always a pleasure to help out a fellow civic owner
cukaracha
Aug 10, 2015 08:01 AM
Civicircus
Aug 6, 2015 11:58 PM
Dani1993
Jul 24, 2015 09:02 AM
sch2cm
Jul 21, 2015 09:58 PM
robbie374
Jul 7, 2015 02:56 AM
