Replacing Throttle Body
Old Aug 6, 2015
cukaracha's Avatar
cukaracha will become famous soon enough
Hey guys,
The throttle body on my 2000 Si is binding and no amount of cleaning is getting it slinky smooth like it should be. I'm looking to buy a replacement TB, but it looks like the OEM part is discontinued.
What's a good aftermarket TB to get? I'm trying to stick to stock bore since I don't plan to replace the intake manifold.
Also, is the procedure for replacing the TB as simple as bolting on the replacement and transplanting the sensors over, and then letting the car run for a bit while the ECU re-learns the new system (at least that's what I've read, but kinda seems too easy...)
Thanks!!
Old Aug 8, 2015
Poopies's Avatar
Super Moderator
Re: Replacing Throttle Body
It looks like Majestic Honda still lets you buy them even though they're discontinued. I was just able to add one to my shopping cart.
Old Aug 8, 2015
cukaracha's Avatar
Yup, you're right. The price is ridiculous though!! What's a good (cheaper) aftermarket alternative?
Old Aug 9, 2015
Poopies's Avatar
Super Moderator
I'm not too sure. OEM would still probably be best, and you might be able to find a decent one at a pick and pull lot.
Old Aug 10, 2015
cukaracha's Avatar
I'd go with used OEM, but the issue is that the throttle body is specific to the Si (unless I'm mistaken) so finding one might be an issue.
davidpaustin
Apr 29, 2015 02:23 PM
green01civic
Apr 29, 2015 01:36 PM
mievil
Apr 28, 2015 11:02 PM
MyOtherRideIsBritney
Bolt-on Engine Performance
Jan 1, 2002 12:58 PM
AnotherDopeStyle
Dec 28, 2001 05:26 PM
