Need Help Painting Piece In Front Of Gauges
Old Jul 12, 2002
TOOLOWCIVIC's Avatar
Hey guys I need help painting the piece in front of the gauges. Not the piece where the gauges sit on but the one in front of the clear plastic. It has 2 screws on top but I don't know if thats all I need to take off and then just stick a flat screwdriver on the side and try to pull it out. I will try to get a picture from the members rides so you can see exactly what I am talking about. But if you know how to take it off can you please help me. I don't want to mess it up.
Old Jul 12, 2002
Fern's Avatar
The Greatest
Fern is an unknown quantity at this point
Go to the Reverse glow guage DIY, it shows exactly (with pictures) how to remove. Basically it requires removing those screws and carefully prying the whole peice out(its held on with clips and some glue so it takes a little effort to remove it). just be really careful not to scratch or crack anything or break off the ***** for the dash illumination or mileage clock. Its not that hard though, i just did it a few weeks ago when I installed my chrome rings around the guages.
Old Jul 12, 2002
Thanks I'll give it a try. Anyone else have any suggestions on how to take it off?
Old Jul 12, 2002
Fern's Avatar
The Greatest
There really isnt any other possibly suggestions, its the only way to remove that peice. theres no other way to do it.
Old Jul 12, 2002
thx1138's Avatar
thx1138 is an unknown quantity at this point
Take out the whole cluster like in the DIY. Take it to a comfortable place and remove the clear plastic by pressing the clips. If you done it once, you'll see how easy it is.
Old Jul 12, 2002
Okay it was really easy to take off and I painted it like the diy said. I put 2 coats of primer and then I painted it with the Plastikote paint. It came out like ****. It doesn't look smooth. It has a lot of bumps from the primer. Was I supposed to sand it then paint it or what. Every time I ad a coat it gets smoother but I already used 2 little cans. Should I sand it or just buy some more paint and keep on painting on top of it? My only problem is that when I went to Pepboys I got the last 2 cans. Will any other color match? I got the honda silver. Will the toyota or any other silver match almost the same as what I already have? Someone please help.
Old Jul 12, 2002
vino's Avatar
vino is an unknown quantity at this point
shoulda sanded it first and i wouldnt try another color silver
edit:btw did you clean it off first??
Old Jul 12, 2002
Well I went to see if it was dry yet and it kinda was but didn't like it so I peeled it off. It came right off. Now I am going to sand it then put the primer and then paint it over. I hope it comes out better this time.
Old Jul 12, 2002
Alright so I read the diy again because it doesn't say to sand it at all and I saw that it said to use white primer. The primer I used was like a dark gray which is darker than the honda silver. That is why I think I had to use so much paint to get the color to come out nice. I think I will wait till tomorrow and buy the white primer and more paint if I can find the same honda paint.
Old Jul 12, 2002
AceKicker's Avatar
AceKicker is an unknown quantity at this point
hey man i did my piece that you are doing I used 1 coat of primer and 3 coats of the aluminum 500degree paint it looks great I get the best compliments about it.
Old Jul 13, 2002
Well I got the white primer and I bought some more silver. I am going to give it a another try. Hopefully I will do a better job. I am only goint to put 2 light coats of white primer.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
usajags84
15
Aug 19, 2015 03:12 AM
werdnahall
May 17, 2015 11:37 AM
cooldan1
Apr 23, 2015 10:49 AM
