header sounds like ass!!!!!
Old Jul 12, 2002
biggs's Avatar
biggs is an unknown quantity at this point
header sounds like ***!!!!!
i just converted my dc sport header to fit my lx, and i really dont know what its suppose to sound like but mine isnt to pretty. if anyone has a sound clip please let me hear it. leave it here or send to brianhoney_11@msn.com. thanks alot.
Old Jul 12, 2002
avenger's Avatar
avenger is an unknown quantity at this point
did you check for leaks, cuz thats probably the problem
Old Jul 12, 2002
GanariGuY's Avatar
GanariGuY is an unknown quantity at this point
i think so too.......... check bolts are tighten and torq enough
Old Jul 12, 2002
AzNmiKex215's Avatar
2k1civic.com O. G.
sorta off topic but..
yo ganariguy wut color is your civic? i havent seen many hooked up 2k1 civics running around south philly.. most of the 7thgens i see in south or philly for that matter are the sedans.. with old wht ladies drivin..
u ever seen my car? its eternal blue.. clear headlights.. 7thgencivic.com sticker on corner windows.. with tint and sidemarkers... im from sw philly by the way
Old Jul 12, 2002
C2i0v0i1C's Avatar
SuperMODrizd
please be real specific on what u did , bc im starting on a conversion monday. dc header for the EX model, then getting the EX downpipe, and does some welding in between and so on, and what did u do about th O2 sensors.
Old Jul 13, 2002
biggs's Avatar
well i took dc sport ex header and connected it to a custom pipe i bent up at a my buddies shop. i used my original muffler pipe, and didnt mess with my original cat in any way so if i need to i can put it back on. anyways, i took o2 sensor off a old ford escort engine i found at the shop the threads fit perfect. then i welded them onto my connection pipe from my header to my muffler. i stuck my hand under and i do feel air coming out. so ill fix it and tell you what happens.
Old Jul 14, 2002
zetaR's Avatar
zetaR is an unknown quantity at this point
C2i0v0i1c----
I got the Kamikaze header put on my 01 LX. I had to lengthen the O2 sensors. Plus, if you're getting a downpipe, then I'm assuming your cat converter is going to be removed. Then you will also need an O2 simulator, so the check engine light doesn't come on.
Old Jul 14, 2002
BLUENVY01's Avatar
BLUENVY01 is an unknown quantity at this point
ok, here it is in simple terms....
on the LX trim car, any header is an upgrade to the airflow coming out of the head. more air usually means more NOISE. i did the EX exhaust conversion with the HP header, HP hiflow cat, and the Greddy Evo catback. now, if youre doin the conversion, it would be wise to stick with all manufactured products, but if u really wanna go with custom exhaust, u can. i would recommend the KAMIKAZI header for anyone wanting a header on their LX, because i've heard that the gains are about the same, and the install is less of a headache, because the KAMIKAZI is designed to fit the LX engine/engine mounts. with HP header, there are many alterations to be done on engine mounts, o2 sensors, etc.. on LX cars. the gains dont jusify the install time/headache/cost....fyi.
Old Jul 14, 2002
BLUENVY01's Avatar
btw... i like the way my header sounds. you can actually hear it, rather than the quiet stock one.
Old Jul 15, 2002
bhaz413's Avatar
Support your local 81
From: In the land of milk and butter, Massachusetts, US
bhaz413 is an unknown quantity at this point
Quote
[hr]Originally posted by: biggs
well i took dc sport ex header and connected it to a custom pipe i bent up at a my buddies shop. i used my original muffler pipe, and didnt mess with my original cat in any way so if i need to i can put it back on. anyways, i took o2 sensor off a old ford escort engine i found at the shop the threads fit perfect. then i welded them onto my connection pipe from my header to my muffler. i stuck my hand under and i do feel air coming out. so ill fix it and tell you what happens.[hr]
did you use the donut seal from the old header?
Old Jul 15, 2002
C2i0v0i1C's Avatar
SuperMODrizd
doin the dc header for the ex, bought high flow cat from autozone for 50 bucks, and the muffler shop is going to make new connectors and put the 02 sensors in and it will all be done, there will be no stock piping anywhere
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
CraigW
Aug 18, 2015 07:06 AM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
S1N7H3T1C
Jul 21, 2015 05:20 AM
Theshwartz35
Jul 17, 2015 11:13 PM
