PDA
View Full Version : General Honda Civic Forum Archive.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. Cigarette burn on seats
  2. anyway to.... *HELP*
  3. DIY: Replacing Pollen Filters & Bleeding Brakes
  4. Srs Diy
  5. Help : rs type b lip
  6. OBD II Scan Tools
  7. Maintenace required light
  8. DC Sports Header and exhaust
  9. CF hood won't close
  10. DIY: Changing your odometer's color
  11. How to remove hub nuts to remove axle?
  12. Side SRS light stays on...and already tried reset
  13. HID H1 Doesn't Fit In TYC Projectors?
  14. want to put a clear led in my oem spoiler like the Mazda 6
  15. what kind of fog lights?
  16. In need of EXACT measurements...
  17. Blocks and Revs
  18. HELP!.. where does this screw go? From clearing lights
  19. O2 sensor question
  20. VacuumLine
  21. o2 simulator prob, no diy here
  22. Just bought some LED's & other stuff... Wondering if i got the right stuff.... Please
  23. tail lights
  24. Changing The Automatic shifter
  25. chosing headlights
  26. Brake Fluid
  27. Anyone know how to replace power steering juice?
  28. Using battery charger
  29. valve cover painting update
  30. extra bolt
  31. RSX Seats
  32. anyone have a diagram or DIY for the rear bumper
  33. need some help...
  34. Headlight Help!!!
  35. Is there a tool?
  36. help: take off a front "bar"
  37. How To Paint?
  38. what are the best alrms available
  39. clearing 00 civic 4 door tails
  40. About the firewall
  41. questions about valve cover painting
  42. EX headers on lx
  43. Sir Derek, question about the DIY of your spare tire
  44. passenger side air bag problem with 01 civic
  45. DIY brake pad replacement and rotor resurfacing
  46. I come in peace! Need some help with a civic.....
  47. how much work is it to remove the spoiler
  48. STR fuel rail
  49. alarm installation?
  50. Rev limit
  51. rear seats
  52. headlight for sedan will fit on coupe or not?
  53. Strut Bar help!!!!!
  54. OMG~ I FxxKED it up~ Plz h31p~
  55. Solved VAFC Check engine light problem!!!
  56. V-AFC On a 99 Lude
  57. For ppls who have AEM CAI on their EX (help)
  58. Got the VAFC working on an HX!!!
  59. Great News From Apexi
  60. Where do i hook this wire?
  61. OBX air intake
  62. can you swap 02 gauge cluster for 03
  63. is it possible to pull that reverse 180 with our vic?
  64. clicking problem please help quick
  65. cd player says "err"
  66. How do you remove the emblems from the trunk?
  67. Exhaust
  68. any one know how to fix lug stud
  69. Nuespeed strut
  70. High compression pistons?
  71. speedometer wire ?.
  72. Interior lights
  73. Does the Piaa 1400 foglights fit our car?
  74. Aiming Projectors
  75. fog lights
  76. Laying carbon fiber (help)
  77. information of painting interior pieces
  78. V-AFC Diy
  79. door sensor stuck
  80. Wing for a 2dr??
  81. Exhaust for my car
  82. ONE more clearing headlights ? :D
  83. Euro Rear Tail lamps
  84. Question Trunk Flop-Flip Stoopid A
  85. Glow Gauges
  86. Does anyone have a clue?
  87. DIY: How To Paint Trim Pieces
  88. install ex header in lx question
  89. Import Engine Codes
  90. I bought Lights for my Projectors Wanna Make sure theyre the right kind help me out!
  91. Projector Headlights
  92. What size turn bulb after clearing headlights on 2003 Ex LED?
  93. Apexi S-AFC
  94. Resetting the Computer?
  95. what is that wierd sound?
  96. HELP: Adjusting Front Toe
  97. question for people who have molded/ seamless bodykit...
  98. problem with headlight
  99. DIY on strobes please...
  100. Oven baked Taillights - HELP!!
  101. engine mounts
  102. Got a question about headlights/ where to buy/ which
  103. I just took 20 ounces off of the front end...
  104. strut bar
  105. I need a DYI: o2 sim
  106. Weight Reduction Idea...
  107. Paints for black housing headlights
  108. Problem installing a tach.
  109. 1.7 liter???
  110. Want to swap engines.
  111. Need Help on Exhaust sound
  112. Need help wiring my tach
  113. Where I can buy an autometer full pillard triple pod
  114. quick help with bolts on stock header.
  115. Hahaha
  116. How do You install a Pod/Pillar on the Driver side?at least a 2 pod?
  117. Something Crazy
  118. Alarm question - ebrake wire, where???
  119. HP shorty header install
  120. help w/auto intake install
  121. Is it save to drill the side under panel?
  122. Aero Sides
  123. Problem Installing CAI
  124. Seat install help please
  125. please explain EX VTEC to me
  126. Need Help Quick!
  127. I've got an idea!
  128. Celica GTS Seats
  129. how to change the instrument cluster??
  130. Brembo blanks?
  131. about the manual vtec switch
  132. OEM security system problem...
  133. Dx header question
  134. Help Pleaaase
  135. Shifter wear and tare
  136. Help: hyper flasher
  137. anyone who has installed racing seats
  138. HELP!!... horn wiring
  139. help w/greddy
  140. Desperatly need help!!!!
  141. how to change alarm sensitivity
  142. is fiberglass bendable?
  143. what engine do i have?
  144. Help with the tach
  145. bleh i want fire to come out my car
  146. bodykit help
  147. what oil filter do we use???
  148. Whats that smell
  149. 02 sensor simulator
  150. For those with catback exhaust....
  151. HELP: Kamikaze 4-1 header and gaskets?
  152. hp racing shorty header
  153. HELPPPPPP!!!!!
  154. Racing seats
  155. what to torque the header bolts to?
  156. Manually switching on VTEC?
  157. service manual
  158. changing the instrument cluster
  159. Pics/Review of JDM ITR Steering wheel
  160. Tein EDFC in 7th Gen?
  161. Dress Up Kit
  162. Manual Transmission Speeds
  163. questions read!
  164. What are the belts that are used with the rvm crank pulley?
  165. 03 Si oil capacity question (I posted this topic in the Si Forum but no reply)
  166. Good Timing Degree For AEM Cam Gear
  167. yup
  168. Flawless Hood Pin Install?
  169. how FAST DOES AN MANUAL GO COMPARED TO A STICK?
  170. best intake for 03 ex a/t
  171. diy clutch install?
  172. hid kits
  173. DIY rear drum adjustment with pics
  174. *ALARM: WINDOWS GO DOWN*
  175. Help!! on Injen CAI Auto
  176. DOH! Trunk sensor
  177. CAI help
  178. a non-swap, non fi'ed way to make more hp on a d17.
  179. Indiglo Guages
  180. DIY BRAKE LIGHTS?
  181. Will RSX mirrors fit on civics?
  182. Question about the ECU on a brand new car...?
  183. muahha remote antenna mod
  184. Valve train mods?
  185. header + catback exhaust
  186. intake and auto trans question
  187. 2000 Type R steering wheel ????
  188. DYI: hp racing header2
  189. k20 swapping for 01 civics...
  190. Question about the AEM SRI...
  191. Console question
  192. CREATIVE INSTALL
  193. Turn off A/C on defrost, etc...?
  194. 2003 headlight removal?
  195. 2003 ex headlight removal
  196. Another E-brake question
  197. exhaust piping...
  198. Hydrolock because of intake
  199. Hydraulic trunk
  200. Toyota Swap?
  201. how can i remove my arm rest?
  202. alarm
  203. Need Help with Hard Wire Radar
  204. N/A power, no FI
  205. HELP!!! REMOVING BROKEN BOLT
  206. removing the top lining of the roof
  207. How can I open my TYC tails to paint them?
  208. drive types question
  209. TSX into a civic
  210. Fog Lights to run with Park Lights
  211. 2k2 clear corners
  212. cam gears, pulleys, fuel pressure regulator
  213. What Voids You Warrenty?
  214. Clutch Engagement
  215. How low can you go...?
  216. Injen CAI intake Problem HELP!
  217. Clearing Headlights
  218. Hello :) & What wrench do I use ?
  219. whistling noise in reverse
  220. 1st gear hits 7k RPM!!
  221. dealer aim my lights for me? i have switched my bulbs.
  222. quick, help, workin on headlights right now
  223. updated! paint for autometer pillars/pods
  224. 12V Power Question
  225. Turn your SRI into a CAI (or at least prevent HAI)
  226. HOW TO!
  227. DIY custom grill?
  228. whats the best legal h.i.d.?
  229. 4wd 7gens?
  230. what tools are needed?
  231. apexi
  232. Honda OEM Factory Alarm
  233. Reset ECU help!!!!!!
  234. Rear SeaTS
  235. How can i smoke up my tail lights?
  236. Does anyone know what this is???
  237. Rev's dont drop?!?
  238. HELP! Dashboard Removal (Dash pad only)
  239. Flowmaster series 60 muffler
  240. DIY: Turn your Headlight to Blue Color
  241. How easy is RSX seat swap?
  242. Taking off Mirrors...
  243. need diy on hid
  244. HELP Rear brakes
  245. HELP!!! Transaxle removal instructions
  246. Another Question about Clearing Headlights?? (Not a repost)
  247. PLASTIKOTE VINYL PAINT
  248. RSX-S sway bar
  249. help wit exhaust`
  250. Best way to get to PCV valve on 96 Civic?
