Resetting the Computer?
Old Jun 12, 2003
tamazoid's Avatar
tamazoid is an unknown quantity at this point
Does restartting the computer better for the car? Cause I heard that if you let your car idle for 10 min, turn it off and take the fuse for the computer out for like 2 mins. Then start the car and let it idle for another 10 mins, and then turn it off and start it again. After, start driving it for a bit... I heard it's suppose to run smoother after installing any mods... Sorry if it doesn't make any sense...
Old Jun 12, 2003
Silver02EX's Avatar
Silver02EX is an unknown quantity at this point
I do it after I install certain mods such as Intake, header, and exhaust. Don't know if it helps or not but I guess it can't hurt
Old Jun 12, 2003
tamazoid's Avatar
Are those the right steps for setting the computer though? Or am I doing it in the wrong order? I also heard that you can do it by unplugging the battery...
Old Jun 12, 2003
Crashoveride's Avatar
Crashoveride is an unknown quantity at this point
I do this if I do any mods that have to do with the cars engine, Intake, exhaust, ect ... All I do is disconnect the battery and then pull the fuse for the computer and let it drain down then after a few min I put it all back together and then start it up and let it run for a bit.
Old Jun 12, 2003
Chrisman8995's Avatar
Chrisman8995 is an unknown quantity at this point
with the newer cars you cant reset the computer with out a scanner, with older cars you could unhook the battery and touch the cables, unhook the battery and pull the fuse, but not on ours if you set a code in the computer you have to have it removed by a shop or someone with a scanner because its in the memory...................
i work in a shop and get that ? a lot
Old Jun 12, 2003
tamazoid's Avatar
damn... I guess that's too bad for us trying to do it at home then...
Old Jun 12, 2003
Da2K1's Avatar
Da2K1 is an unknown quantity at this point
I have a question also.
What i was told was;
Resetting the computer makes it "forget" what it has learned about your driving. It goes back to the default tables stored in it & then from the new data, "learns" how to change to more suitable A/F mixtures, timing etc.. Obviously it needs to relearn when you change some stuff on the car. Everyone reccomends doing this after any mods, but if the computer is "learning" all the time, won't it adjust from it's present state also?
Old Jun 13, 2003
nightkids1's Avatar
Initial D!!!!
is that true?????
Old Jul 12, 2003
detoX's Avatar
detoX is an unknown quantity at this point
yeah..is that true? i read a lot hear that says just pull the fuse for a few minutes and walla. and wheres that fuse im suppose to pull?
Old Jul 12, 2003
robbclark1's Avatar
Retired suspension supermod.
Just disconnect the battery for 10 min. That will reset the ECU. IT will forget somethings, but not everything. Besides it will "relearn" again.
Old Jul 13, 2003
civicvtec1ps's Avatar
Search and Learn
look at the fuse box under the hood.
lowlife9
Oct 6, 2015 04:39 PM
senicalj4579
Oct 2, 2015 10:03 AM
Hutch1051
Sep 29, 2015 09:20 AM
260000milesgoal
Sep 25, 2015 07:41 PM
pfwel1977
Sep 10, 2015 02:16 PM
