O2 Sensor / Recurring Check Engine Light
Old Sep 4, 2015
pfwel1977's Avatar
pfwel1977 is an unknown quantity at this point
I have a 2004 Civic EX Sedan (Automatic) with 187000 miles. I have a check engine light on. I originally got a P134 and P135 code indicating that the upper O2 Sensor (Bank One) needed to be changed. I changed out the O2 Sensor, but the check engine light will not go off. I've cleared the codes and run the drive cycle several times, but the check engine light turns back on several minutes into the drive cycle while the car is warming up. Recently, I unhooked the battery for 5-10 minutes to reset the computer. Again, the check engine light turned on as I was doing through the drive cycle. When I checked the codes this time, I am getting a P1157 and P135. A Honda mechanic told me that since I removed the battery, the vehicle needs to go through the idle learn procedure. I tried this procedure this morning and still no luck after driving the car 30 miles to work. Any thoughts?
Old Sep 4, 2015
GolNat's Avatar
Prelude Owner
Re: O2 Sensor / Recurring Check Engine Light
What O2 sensor did you instal? Brand and part #?
I will delete your other thread that is in the wrong area.
Old Sep 4, 2015
pfwel1977's Avatar
I used the following:
BrandOkay MotorModelOxygen sensorItem Weight4.8 ouncesProduct Dimensions5.9 x 2 x 2 inchesItem model numberOMP-234-9017Manufacturer Part Number234-9017 OEM Part Number 234-9017, SG1362, 36531-PLR-003, 5S5667
Old Sep 4, 2015
BrandOkay
This is hysterical.
Got a real link?
Old Sep 10, 2015
Donahue's Avatar
Donahue is an unknown quantity at this point
234-9017 is a Denso part number, and is not the correct one. you want 234-4122
tylerginevan
Apr 27, 2015 12:29 PM
dragonsblood
Apr 27, 2015 12:28 PM
ashleymmackey
Apr 18, 2015 09:48 PM
dooner24
Apr 14, 2015 07:51 PM
