about the manual vtec switch
Old Jun 7, 2003
smp0083's Avatar
smp0083 is an unknown quantity at this point
Post about the manual vtec switch
Would it be possible to manually switch on Vtec at whatever point you want? I was reading the instructions on the V-AFC, and I know you would have to be sending your own signal to the VTEC solenoid, but what signal does the V-AFC send to the ECU's VTM? Does anyone know anything about this or if this is even possible. Please let me know. Any input is greatly appreciated. we did not get any info on this does anyone have a clue about that
Old Jun 8, 2003
Chrisman8995's Avatar
Chrisman8995 is an unknown quantity at this point
V-AFC
Old Jun 8, 2003
prawdigy's Avatar
prawdigy is an unknown quantity at this point
the apexi v-afc is juss a ivtec/vtec controller so ya.. u can set it to what rpm u want, but u juss cant turn it on and off.
Old Jun 9, 2003
zinkyroo's Avatar
cool beans
zinkyroo is an unknown quantity at this point
Why do you want to adjust it? The factory set it at the best point for the car. Don' t think that if you set your VTEC to engage at a lower rpm you will gain power, because you won't....you will lose power! VTEC works off of oil pressure, if you set it low you do not have neough pressure for VTEC to actually do anything, except lose power and screw your engine over. Only by a VAFC if your building a highly tuned N/A engine(which you probably aren't)
Old Jun 12, 2003
xgodxicex's Avatar
xgodxicex is an unknown quantity at this point
i used to want a V-AFC ... just as a 'just to have purpose, just incase i ever need it' ... plus having digital stuff about my engine and vtec engagement would be a cool thing just to show off lol .... but then i thought about how ur actually screwing with the way the engine is producing power and how much the possibility of screwing up ur engine is with one of these things ........ plus i basically got turned off by the V-AFC when i herd that it needed to be hard wired ahh
Old Jun 12, 2003
smp0083's Avatar
well now some people dont know what there talking about cuz when your vtec kicks in your oil pressure up's so um ya and if u kick in the vtec at around 5k rpm you can feel it pull so much harder and with that u can use vtec when engine check code is on and you well only screw it up if u dont know how to drive!!!!!!!!!!!!!!
WaryDriver
23
Jul 22, 2015 07:18 PM
RIPSAW
Jun 9, 2015 08:33 PM
tmort
May 11, 2015 07:13 PM
Grey
16
Jan 27, 2002 11:34 PM
CiViCPrAnInG2k1
Jan 2, 2002 06:57 AM
