Voltage at AC Pressure Switch?
Old May 10, 2015
tmort's Avatar
tmort is an unknown quantity at this point
I'm working my way through some ac troubleshooting flow charts in the service manual. At the point where it says to check the voltage between the number on terminal of the AC pressure switch connector and ground it says to see if you get "battery voltage". Battery voltage would be about 12-14 volts. I measured five volts.
Elsewhere I have heard that these wires are coming from the ECM. If that is the case I would expect to see five volts.
What voltage am I supposed to see here?
Thanks
Old May 11, 2015
Re: Voltage at AC Pressure Switch?
Whenever you make a thread like this, please post your vehicle info.... model, trim, year, # of doors, trans type, etc. Makes it easier to look up info.
On a 97 the AC pressure switch is part of the AC request signal circuit to the PCM, (according to the wiring diagram I have here) so I would expect to see 5v (or ground if the system is trying to operate).
Request path:
HVAC control panel --> AC thermostat --> underhood fusebox (fan relays) --> Pressure switch --> PCM
The PCM sends a 5V, and the "AC request" is (typically) a ground, which originates within the HVAC panel.
When the PCM detects its 5v has been grounded, it turns on the clutch relay.
HTH
cukaracha
30
Jul 26, 2015 12:01 PM
jzhartman
22
Jul 23, 2015 10:42 PM
mistermenphis22
Jul 13, 2015 04:43 PM
Jul 12, 2015 11:54 AM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
