alarm
Old May 30, 2003
LAKAS187's Avatar
LAKAS187 is an unknown quantity at this point
alarm
on the power locks do i tap into the lock/unlock wires, or the lock/unlock relays?
any help is appreciated.
Old May 30, 2003
JDog2001CivicEX's Avatar
JDog2001CivicEX is an unknown quantity at this point
On my viper/DEI alarm we tapped into the relays and everything has been workign fine for over a year now.
Old May 31, 2003
LAKAS187's Avatar
i have the wires from my alarm tapped into the lock/unlock wires and it does not work, what could be wrong?
Old Jun 2, 2003
LAKAS187's Avatar
Can any one help plz...
my keyless entry with my alarm wont work where are the relays or wires to tap into for the locks, I can't get this thing to work!
Old Jun 2, 2003
4jacks's Avatar
4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light
I tapped into the wires...
Gosh darn it i do not have the wiring diagram..
I will look for it ..
But I found the wires underneth the steering wheel, towards the door.
You can see the wires that run into the door,
I tapped in at that point,
I forget the colors and I forget how much cutting I had to do.
sorry
Old Jun 2, 2003
Darko's Avatar
Darko is an unknown quantity at this point
Most alarms that I have installed u need to use two wires from alarm to hook into unlocking relay one is for lock one for unlock now tell me did u already have power lock or not if they are after market it should be fairly easy to hook up
Old Jun 2, 2003
cambo's Avatar
I wish I was asian
have you looked at this? From the DIY section
its the wiring diagram
Old Jun 3, 2003
LAKAS187's Avatar
Yes i, have seen that wiring chart, and yes my locks came from factory I have a prestige alarm system wich really (sucks) but will have to do for now anyways the wire's for the door lock outputs from the alarm brain are, red (lock) green (unlock) and a red wire whit a black stripe, that on the manual says if you have nrgative door lock's connect the wire to the car's chassis (ground) and if positive door lock's vise versa, So i ask ya'll what is wrong everything on the alarm works except the stinking door locks .
Old Jun 3, 2003
luvvegas777's Avatar
banned from avatar useage
luvvegas777 is an unknown quantity at this point
power lock----white/blue
power unlock-----white/green both (-) polarity
they should be on a grey plug above the drivers kick panel
test----- get a meter and put it on the wire if it shows voltage and then 0's out when you do lock/unlock depending on the wire you are testing then that is the one
Old Jun 29, 2003
skipbarber's Avatar
bump thread.
I just tried to install a DEI viper 790 in sexcivic's car, and i cant get the power locks to work. the pulses coming from the alarm are negative and i tapped the two wires on the drivers kick panel mentioned earlier. i used relays to provide a ground when the coil is energized by the alarm pulses. it doesnt seem to work, what did i do wrong? should i not be using relays at all and just connect the pulse wires to the factory relay control wires?
Old Mar 24, 2004
kalm823's Avatar
kalm823 is an unknown quantity at this point
bump an old thread because I'm having the exact same problem, can anyone help out here?
frank_kleng
Sep 29, 2015 10:55 PM
MamaBear2015
Sep 24, 2015 11:34 AM
meicalnissyen
Sep 22, 2015 06:20 PM
Dsmak
Sep 10, 2015 08:30 PM
First Car
Sep 8, 2015 08:54 PM
