Fog Lights to run with Park Lights
Old May 29, 2003
Steely's Avatar
Steely is an unknown quantity at this point
Does anyone know how to rig the Factory fog lights to run while the park lights are on? I think its cool to see a car driving with only the park lights and fog lights. Thanks
Old May 29, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Find the fog light wires that are probably wired in to the headlight wires and tap them into the parking lights instead.
Old May 29, 2003
gotti's Avatar
Yeah, its that easy. Tap the wire into the parking lights and VOILA!!!
Old May 29, 2003
rzc's Avatar
rzc
rzc is an unknown quantity at this point
Just wondering.. wouldn't that blow the fuse though?
Old May 29, 2003
slystad810's Avatar
Go to Radio Shack and pick up a relay.
Old May 30, 2003
MIT's Avatar
MIT
MIT is an unknown quantity at this point
not just telling what to do, but anyone here really done that~
Old May 30, 2003
bluestreak's Avatar
bluestreak is an unknown quantity at this point
I've got the DEPO brand OEM Replica's, and when I plugged the power wire into the open slot on the fuse box, it does allow me to run the fogs w/ the parking lights.
Old May 30, 2003
rockhound124's Avatar
rockhound124 is an unknown quantity at this point
Has anyone done this?? Please give the info on how to!
On the OEM. I know what the aftermarket styles do.
Old May 30, 2003
Krepoort's Avatar
Krepoort is an unknown quantity at this point
Why not just have the fogs and parking/headlights run independently from each other? So you can just turn on your fogs whenever you like. Thats how I have mine.
-Kre
Old May 30, 2003
Steely's Avatar
I bought my fog light kit from the dealer and installed them myself, has anyone did this modification or are we all just giving advise of what they think will work? If you have done it any advice of How To would be appreciated.
Old May 30, 2003
azn0o7's Avatar
azn0o7 is an unknown quantity at this point
ARe you getting an oem fog light or oem knock-off switch or are you buying aftermarket... if oem then it'll come with a relay switch for your to run your lights while your parking light is on... if not then find a relay switch, radio shack wouldn't have it but you should try autozone or a store like autozone...
Old May 30, 2003
4jacks's Avatar
4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light
I did it with aftermarket fog lights
But your set up should be the same
1) Remove front bumper, see clearing Headlight DIY
2) Take Off one headlight so you can get at all the wires, (Mainly the parking light)
(I used the passenger side an screwed the relay and the grounds into a nice empty section behind the bumper)
3) Reading the wiring diagram for the fog lights you purchased, one wire will run from a swith to the fog lights, hang on to this wire.
4) Splice the above mentioned wire into the power wire for the Parking light of the Headlight you removed. (this is the wire that runs to the center of the bulb)
5) Connect the Above mentioned wire directly to the foglights without any switch.
Your fog lights should now come on with your Parking lights when you turn the **** for the headlights.
Any questions please email me
Old May 30, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
-Kre
THATS what i did too .... u just need a wire tester... find out which wire gets power when the lights are on ... then just give that a constant 12v and the lights will turn off and on without using parking or headlights... its good for that late night race.... cut the lights and race with the fogs
Old May 30, 2003
4jacks's Avatar
it's nice to have the fogs hooked into the parking lights so you don't accidently leave them on and drain your battery,
like i did on many occasion,
When you open the door, it will ding if they are on.
trellex
May 24, 2015 04:39 PM
davidarenberg
May 16, 2015 08:45 AM
NukeSilo
Nov 20, 2001 05:17 PM
klam
Nov 16, 2001 03:36 PM
NukeSilo
Nov 4, 2001 09:37 PM
