HELP!!... horn wiring
Old Jun 7, 2003
diggaflip's Avatar
diggaflip is an unknown quantity at this point
Question HELP!!... horn wiring
i jess got one of them jcwhitney animated sound horn thangs...
well... the wires are like 12 inches long..i need em longer... do I jess buy
any wires and connect to extend it? the horn wire that is supposed to
connect to the controller is two wires stuck together.. but at the end.. they sperate, one
is all black.. and the other is black w/ a white stripe... ( i definitely need to extend these wires so i can place the controller in the glove comp. er somein..... the wires from the controller to connect to the battery are Red.. and then theres another wire... Black... can i connect these (tap these with) the wires that go to my head unit??
Help me out yall......... with wah wires i should buy n how to do it
DiGGaFLiP
Old Jun 7, 2003
konstanting's Avatar
konstanting is an unknown quantity at this point
no idea what to do...but did u check out the DIY ?
http://www.7thgencivic.com/modules.p...howpage&pid=55
maybe that will help you a lil
Old Jun 7, 2003
HCivic02's Avatar
"Stout"
HCivic02 is an unknown quantity at this point
Ok, here it goes. You can buy any gauge wire to make the wires longer, you can also just pull the 2 wires on the horn that are together so they will be alittle longer. The black wire is your ground just put that wire under a bolt somewhere. The wire with the white stripe goes to the controller. The red wire is your power wire you should run that to the positive battery terminal. The black wiire from the controller will connect to the white stripe wire coming from the horn. Now you should be in business connecting all of the stuff up.
Old Jun 8, 2003
Chrisman8995's Avatar
Chrisman8995 is an unknown quantity at this point
kaashifv
Interior
Jul 27, 2015 05:28 PM
ZILLA
Jul 13, 2015 04:52 AM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
ZILLA
Jul 10, 2015 06:05 AM
ZILLA
Jul 5, 2015 05:24 PM
