- only on the 2002 models? what is it?
- possible belt problem
- Painting Altezza's Black Need Help!
- Downpipes???
- Unhooked Battery...Help!
- Anyone know how to install Splash guards?
- difference between injen's intake & race division
- rear camber kit
- foam
- I think I dun did it now...
- PLEASE, help if you can
- Vibrating sway bar and tcs
- Sedan OEM skirt+Exhaust
- Nitrous Question
- Oil Change w/ side skirts ?!?!
- MPG Tach
- Front Door Speakers
- Help... Can't get oil drain plug out!
- Radar Detector and Tint
- Projector lighting problem...
- ghetto remote start/pushbutton start
- Problem with new CAI i just bought and installed...help quick please!
- Bolts to the rear strut towers
- header and random technology cat??
- civics can be fast
- rev hard
- ACURA EL TRUNK LID ON A CIVIC SEDAN
- i dont know how you do it
- Anyone have a stock intake manifold they can sell me?
- Does it hurt my transmission?
- SI's STEERING WHEEL ON EX COUPE
- Funny engine noise.
- For those who want to know about the Saab "variable compression engine"...
- dilemma !!!!!!!!!!!!
- side airbag
- Abs light is on??
- The key hole in the rear deck.
- HeeeelllllPPPPPP
- T-25 turbo on a 2k2 civic lx
- *Removed 3rd BRAKE LIGHT*
- Dash Lights DIY
- removing middle dash
- SRS LIGHT TROUBLE
- Maintaince Required light Help??
- Setting the clock
- k20a/k20c info???
- Need Help: Console Removal
- Rear deck help ASAP!
- Suicide Trunk
- installing an alarm......
- Tie bar usefulness?
- Adjusting the aim for OEM Foglamps
- is rear section's muffler same for 2dr and 4dr??
- Just Installed My K&N FIPK!!!
- Spare Tire Space
- 2002 Civic LX Sedan Alternator rating
- SRS LIGHT
- Angel Eyes = HELP
- What is Hard Anodizing?
- OEM Fog light kit?
- Changing the Cluster DX TO ... Any one with a tach
- Removing the catalytic converter
- Does anyone have tech info about the torch specs on the head??
- Over torqued lug nut
- Just finished retro fitting Audi A6 HID projectors in to TYC Projector
- help on installing octane kit
- How to get the panel behind the door off?
- will prelude gauge pod fit my 2k2
- DIY: CUSTOM Short Shifter
- Short shifter mess up syncro's over time?
- What are these?
- 2 Questions Guys
- need to learn the clutch shift dance
- taillights
- [HELP] Need 12V power supply...
- ### DIY Blue interior lights....
- quick question about strobes
- VAFC Question!
- Grill Painting
- DIY oil change link is dead?
- good adhesive removers?
- RSX Muffler on Civic ?? Hmm
- Tokico RSX???
- Resonator?
- dual exhaust
- Rear Section HELP!!
- Headlght problem
- Clearing Altezza tail lights
- WANTED: Horn wiring schematic diagram...
- DIY: SPC Front Camber Kit
- Clearance with Eibach Sportlines?
- we need more DIYs
- Put a lx/dx cluster in a dx?
- ??-Clearing out headlights for an '02 civic
- How to wire power M3-style mirrors?
- May be getting my internals done at KMS
- OEM style fog lights.............installation?????
- TRANNY SWAP.....questions on the ECM wire harness
- got type r springs
- Water Building on Driver Side Carpet!!!
- Just heard back from the dealer (RE: Sticky tranny)
- Where do the wires from the interior light go?
- Arm rest mounting bracket
- Has anyone heard of a IC chip???
- silly gas tank question
- PLEASE HELP ASAP tech advisors
- Is there a easy way to fix this?(cracked kit)
- Help...odd question
- ROCHESTER, NY
- Kaminari Kit Question
- used springs on a new car?
- NEED HELP...NOPI SHOW IN 2 WEEKS!!!
- revo technica short shift kit help???????
- cargo net hooks removal
- Shaved molding
- Taking car in for Tranny bushing problem, leave Injen on or off?
- Why do Ground Control Coilovers Squeak so much?
- custom fitting parts
- Painted Int, will it last?
- Help with HID Conversion kit installation
- TURBO COST?
- need help with engine..
- DIY: Spark Plug Install
- How to cut through a welded bolt
- enigne swap
- Koni Squeaks?
- Tech Procedure: EM (01-02) Civic Torque Converter for AUTO (From HondaTuningmagazine.com)
- ugggh...im mad
- Easy Turbo question?
- Electrical help
- New exhaust..
- Shift Knob; There's a clip...
- kamakize header
- leather steering wheel cover
- mpg loss with new intake?
- Anyone have a custom intake manifold?
- Cleaning Chrome
- auto to manual tranny swap?
- audible tick from denso plugs
- turbo maintenence
- Removing windscreen wipers
- gauges in glove box diy and custom interior?
- Headlight Eyelids install help
- DIY DVD in Glove BOX????????
- 2000 civic type r cluster
- Sedan Taillight help
- Need Help on exaust
- good info here
- who's running with no resonator?
- Iimmobilizer canadain civic dx
- SMOKED CLUTCH??
- freakin head lamps
- resetting ecu
- Got some problems...need advice
- I now know rim weights, how about tires?
- Relocating Radio DIY
- clearing codes?
- DIY short shifter...
- Where's the Blue Dash Lights DIY?
- My attempt at clearing headligts
- SubWolfer Power Cable
- AEM brakes + Wilwood calipers
- engine ques.?????????????
- ECU newb question
- Stripped screws ?!!!!
- what makes our cars ulev?
- Installing Bypass?????????
- drl light comes up?
- Installed Injen CAI, Car Keeps Stalling : Help
- paint on bolts in engine bay?
- My headlights have Torx screws in them...
- How bad will stock 7443's look behind cleared lights?
- ANY1 Have a Light Bulb Chart?
- Car Scratched...How much should I expect to pay for a new Paint Job?
- what tools do i need to clear my lights?
- Nology Hotwires + Denzo Iridiums = OK?
- Is there a difference between the 6th gen and 7th gen exhaust hangers?
- FOGGED OUT PROJECTOR LIGHTS
- Eibach springs
- Question about shaving keyhole...
- Clearing lights despite the weather?
- Removing Dealership sticker
- Interior Trim Peices
- will the paint chip if i drill into the fender
- Type-S Engine Swap Price...
- fuel rail
- Nitrous ? on Si
- Cam shaft question
- Just got a call from the tint shop....
- oem oil filter ?
- K&N drop in filter
- I need a DIY for removing sedan back bumper
- OEM sedan and coupe front skirts
- Removing side air vents?
- What is our injector size rating?
- Advice on installing Tsunami front bumper and Wings West side skirts
- I need some help !!!
- Do I clean or replace AEM CAI filter?
- Pulley Help
- injector question
- How to turn off A/C when on Defrost Setting, someone posted it b4, cant find it?
- ? on motor mounts
- Lube job?
- VALVE COVER PAINTING
- Lower Tie Bar
- tinting windows Q!
- help on painting trims n tail lights
- I NEED MORE POWER ON MY LX!!
- Gauge cluster
- wow...i'm screwed
- lowering questions
- my dumbest question EVER!
- lx exhaust
- Auto Paint
- HP 4-1 header w/ high flow cat
- intake for seattle
- quick wing question...
- INTERIOR LIGHTING???
- Intake Question
- Just installed Injen SRI !!!!!!!
- Does tint effect the rear defroster?
- z3 fenders
- Painting headlights
- recalls & tech stuff you need to know
- FIPK's?
- Window Question/Problem
- LED install*
- wig wag module install???
- Just installed Revo Short Shifter
- Shift Knob Question...
- remote turn-on from amp keeps blowin cig lighter fuse!?!?!??!??!
- injen filter size?
- Prob with Injen CAI
- Just removed stock intake snorkel only.. Its ok?
- MY ANGEL EYES ARE FOGGING UP!!!!!
- Blow Off Valve Sound
- spark plug...
- body kit questions ?
- turbo :-D
- how do you sand urathane?
- vtec head swap to lx (searched)
- oil pressure sending unit?
- Does anyone know of any DC5's that are boosted?
- a dumb question about the ecu
- CD Player Trouble - Please HELP!
- Manual tranny question: GL4 or GL5?
- Ground Control HELP
- any RSX TYPE S sway bar for sale???
- How to remove handle from door handle assembly
- Stock Rims Weight???
