How to cut through a welded bolt
Old Oct 2, 2002
JKEEZO's Avatar
JKEEZO is an unknown quantity at this point
alright, i snapped off 2 of my header bolts and i need to remove/replace them
heres what i need to know, when i open up the exhaust manifold i need to take out the bolts from the back but they are slightly welded in place... what is the best way to remove the bolts (to get through the welding i guess) ???
Old Oct 2, 2002
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
blow torch
Old Oct 2, 2002
JKEEZO's Avatar
im thinking some sort of saw
Old Oct 2, 2002
JKEEZO's Avatar
is there any way to find out the size of the bolts that are supposed to be where the blue lines are??? or do i just have to take them out and match it up
Old Oct 2, 2002
Ducatti's Avatar
Ducatti is an unknown quantity at this point
Quote
[hr]Originally posted by: JKEEZO
im thinking some sort of saw[hr]
Good luck sawing through a weld, youre gonna have to use a blow torch
Old Oct 2, 2002
JKEEZO's Avatar
the way he described it it sounded like they werent really welded on all that well
Old Oct 2, 2002
zero's Avatar
zero is an unknown quantity at this point
Call some different mechanic shops. They should have a specialize tool to remove it. Its a reverse drill bit that they use to drill into it and then they just use another nut to screw into it and there you go......
You could buy it yourself but those bits cost hundreds for a set.
Old Oct 3, 2002
aetobatus's Avatar
n00b
aetobatus is an unknown quantity at this point
sears sell some special bolt that allows you to remove strip bolt.
Old Oct 3, 2002
ce01cvcex's Avatar
ce01cvcex is an unknown quantity at this point
sawzall, ie dewalt reciprocating saw with metal cutting blade. if they are just tack welded, you could probably knock them lose with a light tap with a hammer or something of that sort. thats how my father removed some tack welded bolts from our domestic project car i am helping him work on, he was a mechanic at one time, and was also a welding instructor where he used to work, not sure if i'd take that risk if you arent too sure about that though. you could always hire someone to do it for you too.
Sep 27, 2015 11:33 AM
h4ldol
Sep 10, 2015 12:25 PM
Ultra Havoc
Sep 9, 2015 10:58 PM
redcloud
Sep 7, 2015 01:45 PM
muttleytm
Jul 14, 2015 05:31 PM
