Installed Injen CAI, Car Keeps Stalling : Help
Old Sep 28, 2002
netcbc's Avatar
netcbc is an unknown quantity at this point
I helped my friend install his Injen CAI into his 2001 Civic Manual Coupe Si/EX
We installed it totally correct because i did one on my 2001 Civic Auto Sedan LX
We tried resetting the ECU by taking off the negative part of the battery for a while,
everything is fine when he is in neutral but once he goes over 2k RPM in 1st gear, the car shuts off........ wuts wrong?
Old Sep 28, 2002
CapYoda's Avatar
Escaped Convict
best way to ensure that you have reset the ECU is:
take out the ECU fuse in the fuse box. disconnect it for 10 minutes.
after that, plug it back in, start the car and leave it on for 10 minutes.
then, turn off car, but dont press on gas... and turn it off again.
finally turn it on and you should be good to go.
Old Sep 28, 2002
AceKicker's Avatar
AceKicker is an unknown quantity at this point
I would say jsut try driving with it for awhile and maybe the car will get use to it. or u might want to tighten the throttle cable too. maybe that might help
Old Sep 28, 2002
pogi2k1ex's Avatar
pogi2k1ex is an unknown quantity at this point
did u even mess with the throttle cable???
check the air sensor make sure its in right or that it wasnt damaged...
before u installed the intake did you make sure there wasn't any of that peanut packing crap in one of the pipes or the filter...that would suck
Old Sep 29, 2002
PoopyRay's Avatar
PoopyRay is an unknown quantity at this point
If the peanut packing is styrofoam then the gas will disolve it over time, infact, if you read maxim magazine, gas and styrofoam is a good way to make napalm!! hehe
Old Sep 29, 2002
netcbc's Avatar
my friend is guessing that its the intake that is touching metal at the bottom where the mushroom is, do u think it could be that?
Old Sep 29, 2002
CapYoda's Avatar
Escaped Convict
mushroom? u mean the filter?
the filter shouldn't be touching anything right?
check if the pipping is hitting anything. check the ground wire too, I duno. just double check everything u installed.
did u do what I suggested on the ecu resetting?
Old Sep 29, 2002
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
Quote
[hr]Originally posted by: netcbc
my friend is guessing that its the intake that is touching metal at the bottom where the mushroom is, do u think it could be that?[hr]
I was thinking the same thing. The filter might be pushed on too far, so the end of the filter is too close to the end of the pipe. The higher RPMs might make the vacuum enough to suck the end of the filter to the intake, causing a loss in airflow. Just my guess....
Old Sep 29, 2002
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Maybe you forgot to ground the cables [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Sep 29, 2002
netcbc's Avatar
i mean the bottom intake pipe is touching the metal firewall .......... could that be the problem?
Old Sep 29, 2002
naw, that shouldn't be a problem. Mine was touching after the rubber pad got rubbed off. [IMG]i/expressions/face-icon-small-frown.gif[/IMG] I redid it with a piece of corrugated wire loom over that metal piece. It helps.
edit: bah, I can't type. Those keys are not even right next to each other!
ph0ng
52
Mar 4, 2003 09:15 PM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
burtn6
Nov 4, 2001 09:20 PM
JeffSpeed21
Nov 3, 2001 10:32 AM
Wanger
Oct 19, 2001 10:37 PM
