Nitrous Question
Old Oct 12, 2002
Ike's Avatar
Ike
Ike is an unknown quantity at this point
Nitrous Question
Do you have to drill a whole in your engine to install nitrous or is there another way? I know that the AEM fuel rail has a port for nitrous and whats that all about?
Any responses would be appreciated.[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Oct 12, 2002
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
Nitrous Express DIY c/o hondatuning
Old Oct 14, 2002
Red2k3Civic's Avatar
Red2k3Civic is an unknown quantity at this point
you probably need to either have it done professionally, or do a lot more research before installing n2o. Two things have to be modified. First you will have to drill a hole into your intake piping (if you have aftermarket intake). If not you will drill a hole in your airbox and put the fogger there. I dont suggest the latter. The second thing you have to modify is your fuel line, installing a T that taps into the fuel line bringing in fuel to the fogger (assuming your running a wet kit).
The only time you would ever drill into your "engine" and thats a very very very loose term, would be direct port nitrous injection, when you drill into your intake manifold.
Old Oct 14, 2002
JoeB16's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way Galaxy
JoeB16 is an unknown quantity at this point
no. it completly depends of what type of N20 system you want, and then it depends on what style (ie, wet, dry, direct port wet, etc...) minimal will have you drilling nto your intake and splicing the fuel/vacume line. most will require you to tap ports into your intake manifold.
Old Oct 14, 2002
PlatCruiser's Avatar
PlatCruiser is an unknown quantity at this point
or for the fuel source you could skip the T fitting and yes tap into the fuel rail such as the AEM for fuel (wet kit)
Old Oct 14, 2002
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
If your not experienced and wish to DIY it i suggest ZEX, it is a dry fogger system and very easy to install you will need to drill a port in your Intake facing the jet's toward your TB, and run a vaccum line to a FPR. If you want a wet system there are other brands NX/NoS etc etc and i suggest professional install due to the complexity of the system's.
Old Oct 14, 2002
mohawkboom's Avatar
Quote
[hr]Originally posted by: xblkcivicx
If your not experienced and wish to DIY it i suggest ZEX, it is a dry fogger system and very easy to install you will need to drill a port in your Intake facing the jet's toward your TB, and run a vaccum line to a FPR. If you want a wet system there are other brands NX/NoS etc etc and i suggest professional install due to the complexity of the system's.[hr]
Returnless fuel system in the 7thgens..no Vacuum line..can't run dry kits.
Old Oct 14, 2002
Mbow's Avatar
I don't think that the install looked too bad at all.
Exactly which system would be best for our cars? Not really looking for brand, just like which system to get from nitrous express for example.
Old Oct 14, 2002
wet would be the easist to install on a returnless fuel system.
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
junkyardguy
Sep 2, 2015 06:07 PM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
