Put a lx/dx cluster in a dx?
Old Oct 5, 2002
Doug's Avatar
Doug is an unknown quantity at this point
ive seen people that have put the ex or lx cluster in a dx due to tach. Does anyone know how and if so any other tools wires need?
thanks
Old Oct 5, 2002
CivicManDan2's Avatar
CivicManDan2 is an unknown quantity at this point
no tools needed other than a "phillips" screwdriver. i did it to mine. total romoval and install time is 15 minutes. put the tilt steering down all the way. carefully romove the top of the steering column. (no screws, just snaps on). you have 2 screws in the cluster visor. remove them. the hardest part is pulling out this plastic visor peice. its held on by some kind of 2 sidded tape in back. just pull straight out. be careful not to break the trip meter or dimmer ***** if you pull down and out. remove remaining screws. unplug.... and reverse the steps.
Old Oct 5, 2002
Doug's Avatar
what about the tach though dont you need to do something because the dx doesnt have one and the new one will have it?
Old Oct 5, 2002
civic4dr2001's Avatar
civic4dr2001 is an unknown quantity at this point
nope it will work with no extra wires
Old Oct 5, 2002
Doug's Avatar
okay thanks for the help guys
Old Oct 5, 2002
Bellz's Avatar
This will also change your mileage in the odometer, right?! [IMG]i/expressions/face-icon-small-sad.gif[/IMG] And whats the legal repercussions of switching a gauge cluster? Should you swap it back when you eventually trade cars, or what? What's the odometer on the original cluster going to show when you reinstall it?
I know this was in another thread, but it's relevant here too. I'm also considering this, as I have a DX also.
Old Oct 5, 2002
it was my understanding you have to write down the ending milage of the tach you removed. check your local DMV. some have a form you must fillout, and is notorized. i kept my old cluster in case. and write down the milage of the cluster when you put in the other. keep good records i guess.
yes it is just a plug-n-ply type deal. there is a tach wite that already exists even in the DX harness. the diagnostic tach wire most people hook up a "monster tach" type to is under the hood on the passenger side in between the battery and the fuse box i think
trellex
May 24, 2015 04:39 PM
jimmyfloyd
May 20, 2015 07:06 PM
Ma213802
May 18, 2015 07:01 AM
One_PeeJay
May 17, 2015 05:31 PM
bahena08
Apr 11, 2015 05:09 PM
