Electrical help
Old Oct 2, 2002
juscallmetoyota's Avatar
juscallmetoyota is an unknown quantity at this point
Electrical help
Ok, I was about to turn off my car when all of a sudden my stereo went out. My keyless entry don't work, dome lights don't turn on whn I open my doors, Stereo don't work, when I turn on my headlight theres no beeping sound, and when I insert my key into my ignition theres no beeping sound. I checked the fuses underneath the dash and even under the hood, its all good. What the hell is wrong? Please help.
Thanks,
Steve
Old Oct 2, 2002
DatJuice's Avatar
DatJuice is an unknown quantity at this point
umm.....check ur fuses again cuz it sounds like the DOME fuse !!
Old Oct 2, 2002
BrotherSound's Avatar
BrotherSound is an unknown quantity at this point
Kinda sounds like a problem I had,.. Does your Trip-odometer reset itself when you turn off your car?... if so its a fuse in the fuse-box under your hood, I think its labeled option.. try that
Old Oct 2, 2002
htowncivicEX's Avatar
htowncivicEX is an unknown quantity at this point
Check to make sure the main ground line is connected correctly.
Old Oct 2, 2002
JoeyCrack's Avatar
JoeyCrack is an unknown quantity at this point
If u have a CAI, it could be the ground ......[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Oct 2, 2002
TwilightX's Avatar
TwilightX is an unknown quantity at this point
Defninitely sounds like a fuse issue...
Old Oct 2, 2002
BlueFlame's Avatar
BlueFlame is an unknown quantity at this point
Yeah, I'm 99.8% sure it's a fuse thing. I had that same problem myself, and it was a fuse. Actually there were 2 fuses, both in the fuse box under the hood. I believe one was labeled something stupid like "small light" and that's the one that turns out to be the most important one in the interior as far as lighting. So I would suggest checking that, and then if you use the spare that comes in the fuse box, don't forget to pick up another pack in case you ever need to replace the fuse again.
When mine blew I had no dash lights, no headlight beeping, no dome light, no tail lights, it was horrible. Anywho good luck with getting that taken care of.
Peace.
Old Oct 2, 2002
APS's Avatar
APS
APS is an unknown quantity at this point
Grab yourself a cross and a priest....sounds like your car is possessed...[IMG]i/expressions/laugh2.gif[/IMG]
cferry7
Oct 18, 2015 06:32 PM
Solo Flow
Oct 4, 2015 07:52 AM
thebmillz
Electronics
Oct 2, 2015 08:38 PM
Bruce2
Sep 27, 2015 08:45 PM
beanhead
Sep 24, 2015 12:04 PM
