possible belt problem
Rep Power: 0 possible belt problem
i think maybe my belt is making a squeling noise every now and then. i was wondering if i need to change it. i have about 60000 miles on my car so I'm thinking it can"t hurt. anyone one else have an opinion about it? also does anyone know if there is a Hanes or Chilton manual out for the 2001 yet?
Rep Power: 0 Also, if I did need to replace the belt, does anyone know where I could get one? None of the local parts stores have them , if I have to go to the dealer, do you think itll be expensive?
Rep Power: 0 60k miles is about what a belt can take b4 it breaks apart,timing belt replacement schedule should be inside the owner's manual,honda official shop manual is about $70 shipped.dont know about the chilton.
Rep Power: 0 well there is only two belts if im not mistaken, but I figure it can't hurt to go ahead and change them both. So, if anyone knows how to change either of them it would be helpful. I'm assuming the accesory belt has a tensoiner on the other side of the tire, but I haven't looked yet, so I don't know. I guess the other smaller belt would be the timing belt? any knowledge about my car would be helpful. I know a good bit about cars but there is a little bit of stuff that is a little different than most cars. ok then thanks.
chris
chris
Rep Power: 0 coolness is right, there are two belt, if there just squeling and are in good shape just tighten the belts, the bolt for tightening the a/c is right next to the power steering resevoir and the other is kind of hard to get to but is derectly below that and thats the altanator one. i used a socket wrench with a 1 1/8 socket on it and a long wrench, it's really geto but it worked great. If you need to replace the belt your dealer with have them but i have found them at car quest and napa of $26 for the both of them. but those were the belts for aftermarket pullies, but still, they're cheap
Rep Power: 0 actually, it's helmsinc.com, and here's a link to the 2001 civic service manual
Helms manual for 2k1 Civic
CarStuff
12-06-2020 12:52 PM
marciano117
06-25-2015 09:06 PM
