spark plug...
Old Sep 21, 2002
Voiceofid's Avatar
End Bringer
spark plug...
just got the new denso iridiums into the car, here is a pic of the stock spark plug, my car has 24000 miles
can someone tell me why is it like that? none of my friends can give me a straight answer, one of them never seen something like it. is it because i beat on the engine too much?[IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-frown.gif[/IMG]
Old Sep 21, 2002
Hiwind's Avatar
Hiwind is an unknown quantity at this point
are our spark plugs underneath the plasma coils?
what do u need to take them off?
Old Sep 21, 2002
Voiceofid's Avatar
End Bringer
you need a socket with the rubber surround, a 10mm socket and a flathead screw driver, use the flat head to take the sparkplug wire cover off, use the 10mm to remove the coil thing and then use the socket with the rubber suround to remove them
Old Sep 21, 2002
vdub's Avatar
vdub is an unknown quantity at this point
I haven't found out why they do that. I toke my out a 3,000 and they were all brown lookin,but not that bad. I had a Neon R/T that did the same thing. I'm kinda getting to the point that all of the plugs that go down into the engine like that will do this. Don't realy know? Wish I could give you an answer because I would like to know to. I've heard it's the arking from the wire to the plug????[IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Sep 22, 2002
CivicPro01's Avatar
CivicPro01 is an unknown quantity at this point
why do you need the rubber socket thing??
Old Sep 22, 2002
xHoteKx's Avatar
Tomotor
xHoteKx has a spectacular aura aboutxHoteKx has a spectacular aura about
Quote
[hr]Originally posted by: CivicPro01
why do you need the rubber socket thing??[hr]
im guessing so you dont shock yourself?
Old Sep 22, 2002
vdub's Avatar
You need a socket with a rubber center in it so you plug doesn't just fall in the hole and bend the end of it. Also so you can get it out unless your using pliers or something.
Old Sep 22, 2002
Voiceofid's Avatar
End Bringer
no one can explain this and it's doing it on all 4 of my stock spark plugs, i guess i'll birng them to honda and see what's up
Old Sep 22, 2002
2Hottie's Avatar
2Hottie is an unknown quantity at this point
I had the same situation! I replaced the stock ones with Iridiums, and my stock plugs were like that....even after a year of having the car, it scared the heck out of me to see em like that!
2Hottie
Old Sep 22, 2002
Mbow's Avatar
I have never seen a plug come out of a car that didn't look like that. I am almost certain it is completely normal. I have no idea why though.
Old Sep 22, 2002
JohnnyLee's Avatar
7thgen guh chee
I should check mine out later
Old Sep 23, 2002
StLVtec's Avatar
StLVtec is an unknown quantity at this point
Seems easy to install, howlong tops does it take. Looks like ill be ordering some
Old Sep 23, 2002
Voiceofid's Avatar
End Bringer
less than 5 minutes
Old Sep 24, 2002
tummyboy's Avatar
tummyboy is an unknown quantity at this point
I love my Irridiums but you know what guys.. its sounds like and from what the picture shoes that you guys had standard Denso... i had NGK in mine. and I bought my car from a dealer brand new. weird uhH???
as far as the brown stuff that is normal. other than the tip thats the hottestest part of the plug because of heat transfer from the block .. I cant think of a car I owned that didnt have a little bit of brown on it.. but the harder you drive it the hotter it gets so one car may have more than another
Old Sep 24, 2002
Mbow's Avatar
Quote
[hr]Originally posted by: tummyboy
[hr]
That is because honda uses both brands....
Old Oct 10, 2002
tummyboy's Avatar
was not aware of that. thanks for the update... well Iam glad I have denso now.. seems to be a much better plug in my opinion
solarpunk70
Apr 12, 2016 11:43 AM
Bruce2
Sep 27, 2015 08:45 PM
Styven Szastur
Sep 23, 2015 05:26 PM
pilebuck13
Sep 21, 2015 10:45 PM
Bman2212
Sep 2, 2015 11:49 AM
