1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
1994 civic d16z6 no spark..
Old Sep 2, 2015
Bman2212's Avatar
Bman2212 is an unknown quantity at this point
Ok so I got the car and had to replace the starter right away... Did that, then lost spark.. So been reading these forums before creating an account.. I have don the following...
1: main relay (new)
2: new distributor (cane from a running z6)
3: wires (new)
4: checked all fuses (all good)
5: tried grounding the dizzy to see if I needed to look for bad ground (no difference)
Could a bad ecm cause no spark? I'm getting fuel I have no spark and have no idea why
Old Sep 2, 2015
mikey1's Avatar
Re: 1994 civic d16z6 no spark..
test your coil?
how are you checking for spark?
connect a timing light and crank the engine, does the timing light fire?
Old Sep 2, 2015
Bman2212's Avatar
I pulled wire and tried going to a ground for spark, also went straight to the dizzy and to ground as well
usajags84
May 10, 2015 08:11 AM
locozoko
Apr 6, 2002 09:00 PM
Cilvic
Nov 15, 2001 04:54 PM
silvervtec01
Nov 4, 2001 06:56 PM
WeRkX
Nov 1, 2001 10:33 PM
