PDA
View Full Version : General Honda Civic Forum Archive.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 [35] 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. header and exhaust for the dx
  2. ECU upgrade for the civic DX yes or no?
  3. rear disc break conversion
  4. cutting head cylinder
  5. e-brake change in 03 coupe M/T
  6. OEM fog light problem
  7. find these 2 wires
  8. find these 2 wires
  9. find these 2 wires
  10. how do i remove that plastic around the shift?
  11. intake question? did a search!
  12. Is this worthy of a DIY?
  13. I made my own "Ground Wire Kit"
  14. projectors broke! help!
  15. Smoke rising from newly installed header?
  16. Do I have to use the donut gasket when installing a shorty header?
  17. DIY Throttle body heater bypass
  18. universal mufflers... any difference?
  19. Neons and relays and parklights oh my - HELP PLEASE
  20. Grille Craft Front Upper Grille
  21. which iridiums????
  22. How to wear out a pressure plate?
  23. DIY water temp guage?
  24. temporary solution to cleared headlights
  25. i have a question!!
  26. Head Light Wiring Question
  27. drilling thru RAZO pedal
  28. Where's the stock temp sensor?
  29. those with kamikaze or hp header
  30. lower grill question
  31. making a kit
  32. Idea #1
  33. Wanna Go Manual From Auto
  34. B4 i get started
  35. bomex mirror... wiring help!
  36. Exterior
  37. Trim DIY?
  38. revo technica instal
  39. Speed sensor location
  40. did AEM cam gear work a lot
  41. battery question
  42. how do i ajust my headlight (projector)
  43. Nirtous Bottle
  44. Right way to increase idle?
  45. Intake
  46. Ecu k20 question
  47. Dent Wizard/ding King?
  48. what do u think
  49. Opened hazard switch pictures??
  50. Fuel Injector cleaners...?
  51. Is this normal with a 7th Gen Civic?
  52. Urgent: KDC Mirrors!
  53. interior change
  54. Header from NOPI
  55. 2003 Maintenance Light?
  56. throttle linkage DIY'ers, quick question...
  57. can you take
  58. skirt install??
  59. Help!!!!
  60. cleaning filter?
  61. exhaust probs
  62. Advanced Impurt Tuning
  63. BOOM!!
  64. wiring question? help quick!!
  65. Required 4 YOU!!!
  66. ECG O2 Sim
  67. V-AFC Vti on/off?
  68. B-series question.....
  69. cheap and fast
  70. Leather Installs
  71. Will I Get Dominated?
  72. RSX 5 lug conversion with rear disks
  73. civic si radiator
  74. apexi v-afc
  75. DRL
  76. Ebay cold air intake, can I follow the DIY for it?
  77. The K20 Questions
  78. paint ratio measuring cup
  79. 3 O2 Sensors on a D17A6!!?
  80. Headers
  81. O2 sensor
  82. Exhaust back pressure
  83. Installing RAZO RA89 auto shifter, please help!
  84. Hey Guy`s , I Need Your Help , Thanks !
  85. CF hood won't lock into place
  86. is this dyno correct
  87. What's the Difference
  88. catalytic converter
  89. I Need Your Help
  90. Removing Windsheild Washer System
  91. No more cracked/broken Fog's
  92. Quick foglight help.....
  93. AEM brake pad problems
  94. M3 Mirrors Install?
  95. CF hood
  96. might clear heads in a second, need a lil info
  97. Fiberglass or Urethane
  98. Anyone have a DIY to change steering wheels
  99. 01+ Honda Civic Spoon Sports Rear Strut Tower Bar
  100. how do we remove this piece for sedan?
  101. Rattling in the engine
  102. 03 JDM CIVIC Type R steering wheel fit in my 02 civic ?
  103. leather installation
  104. 03 Cluster Swap into 02
  105. How to install shorty header?
  106. Painting Atezza tailights
  107. HELP!!!! altezza grills install
  108. Wire through firewall?
  109. A HID Question
  110. ECU Chips
  111. Transmission Gone OR CLutch GONE? HELP!!
  112. ok to not run 02 sim?
  113. Dyno on a laptop
  114. parking bulbs to match H4 sylvannia silverstars
  115. VTEC set in?
  116. power source???
  117. how much HP do you think i have?
  118. XENON Side skirts
  119. DIY: A'PEXi Rev/Speed Meter Install
  120. Fan Dimensions?
  121. Suggestions on exhaust setup....???....
  122. Oil temp gauge?
  123. INTAKE differences
  124. Ecu
  125. Injen cai
  126. Can a "Universal muffler" be modified into a mendrel bend exhaust?
  127. flip flop trunk gas struts?
  128. Intake mod
  129. CAI and Water
  130. Major tune up project
  131. do our cars have this
  132. So Are 7440's illegal?
  133. 2 questions
  134. How to install Type B front lip (pics)
  135. keypad ignition
  136. 2k2clutch into 99si?
  137. anyone kow how to change door fabric of a sedan?
  138. retail of stock EX seats
  139. pillar gauge pods... how to?
  140. Which Helm service manual do I need?
  141. D17A2 swap question
  142. Opening Taillights?
  143. has anyone changed out there seats?
  144. Fans
  145. Torque on DC Sports TCS Exhaust
  146. Rev Limiter Removal Or Extention
  147. e-brake handle removal
  148. do i need any special tools?
  149. m3 mirrors
  150. need DIY for automatic shift boot
  151. Mileage question
  152. Will an RSX Type S Head fit our engines?
  153. Q: Venom ECU and NX nitrous...?!?!
  154. what kind of 4 point harness
  155. cold air intake
  156. help again
  157. Gauges sticking, please help!
  158. Pulling out timing?
  159. auto for std tranny swap??
  160. removing gas door
  161. Wings West G5 Rear
  162. Opening Tailights
  163. DIY: Hood Pins Install
  164. aem cai manual
  165. DIY: Carbon Fiber Hood Install
  166. rsx sway/evo cat combo
  167. CAI or SRI??
  168. Exhaust System Question
  169. Block pic
  170. Removing the parking brake?
  171. ECU question?
  172. DIY Seat Install????
  173. I'm approaching 20K and haven't had any service done besides oil changing...
  174. Venom 400 Installation
  175. how do you remove 3m double sided tape?
  176. AEM Replacement Air Filter?
  177. SRS light question
  178. it's funny. haven't you noticed when you're driving w/the AC on...
  179. Painting Trim... Need Help
  180. Changing Headlights...
  181. Lip Bracket
  182. burnt gasket, backfire, stripped threads.. hmm. lil help. lol
  183. puttin my laptop in the glove compart. need help
  184. NOS and Our cars
  185. Exhaust Smell
  186. Right Hand Drive
  187. how do you put on injen heat shield on filter
  188. K2O Swap?
  189. ebay intake?
  190. front bumper question
  191. DIY AEM Short Ram Intake install
  192. Tanabe Exhaust
  193. changing interior-beige to black
  194. 03 Coupe EX auto center console ?
  195. Idle
  196. Help!
  197. mtf
  198. Centre console swap?
  199. race chip
  200. TYC taillights mods
  201. weight
  202. cant get off drum cover
  203. Newbie - Air Intake and Strut Bar question
  204. got my gx pistons finally installed!!
  205. just tryin to get opinions on electronics...
  206. I'm Ghetto!
  207. change oil light
  208. trying to get this piece out to paint it
  209. Headunit Installation in pocket
  210. 7thGen'er needs fog light help
  211. RSX type S fuel system swap?
  212. Apex-i rev install??
  213. how to install tyc projectors????
  214. roll control install
  215. Auto Shift Kit
  216. cant lower my vic?
  217. Adjusting the throttle cable
  218. Dose 7thgen side mirror fit with 6thgen mirror (both coupe)
  219. compression ratios?
  220. Bomex Side Skirts????
  221. FYI : lots of DIY......
  222. installing glass-pack in place of...
  223. k&n fipk II install
  224. Front Bumper Removal for a 'factory performance' civic...
  225. Civic Brush Guard
  226. Exhaust install help
  227. Rear lip starting to gap with heat
  228. If I put racing steeringwheel(No airbag) and reset SRS the srs light still ON???
  229. Aem Cai 01 Lx
  230. bumper prep and primer
  231. Gunmetal vs. Black .. on black
  232. V-afc
  233. Anyone Take On & Off their BUMPER so much, it does not fit good no more??
  234. Replacing interior cabin filters
  235. Adjusting TYC WITH HID?
  236. orange reflectors
  237. 02 sensor problem
  238. Carburetor help
  239. tornactive gun metal headlights need help fast!!!!
  240. Horn not working!!!!
  241. Which oil would you recommend????
  242. Gauge Jumping??
  243. VTEC engagement
  244. 1992 Civic EX Starter
  245. anyone knows how to remove the circled part?
  246. Angel Eyes for 03 Acura 1.7 EL
  247. Anyone unsealed their TYC taillights?
  248. KMS intake manifold DIY
  249. how much would it cost...
  250. How do you take off our door panals?
