CF hood won't lock into place
Old Jul 14, 2003
XxJDMCivicxX's Avatar
I took off the hood levelers but the hood still doesn't pass the first latch and lock into the 2nd one. I pushed with all my might and nothing. Any ideas I tried bending the latch but that doesn't really work i'm a bit affraid of breaking the latch and not having any support at all.
Old Jul 14, 2003
GoOkStA's Avatar
GoOkStA is an unknown quantity at this point
where u get the hood from?
Old Jul 14, 2003
The hood is made by XRL they make a bunch of hoods for different brands and styles. I'm attaching a pic of it what it looks like right now.
Old Jul 14, 2003
CarbonFly's Avatar
Install your hood pins and remove the stock latch.
Old Jul 14, 2003
Yukonart's Avatar
Yukonart will become famous soon enough
Yeah. . .and if the hood's supposed to have the latch work with the factory lock, then ask the company that made it how it might not be working.
Another option is to take off your bumper and see how it's trying to latch down. . . you should be able to see what's going on, then.
Just curious. . . has anyone else told you that your headlights look like the new Cavalier headlights having those covers on them? And do your turn signals actually shine through them?
Old Jul 14, 2003
WhiteRabbit's Avatar
try seraching, there was a comprehensive fix to this problem.
the easiest and by far worst way to fix it is to notch the larger diameter hook on teh carbon hood. itll work, but over time it will wear the piece through.
the best fix is to notch the latch itself, but is very difficult to get the tooling in there. however, you will get reliability as well as a solid fix.
hunt down the last thread about this if you want the comprehensive info about it
Old Jul 15, 2003
wonderz's Avatar
wonderz is on a distinguished road
hm...my cf hood seems like it wouldn't close when i first got it. Then I took it to my body shop, and they just push it right in no problem. The trick for me is to use BOTH hands, and push the hood where the notch on the hood is. But if u already messed with the factory latch, its might be hard to do it.
btw, if u install hood pins, can't someone just walk down the street just open up your hood and take your stuff? assuming you removed the stock latch
Old Jul 15, 2003
Da1lyDr1ver's Avatar
did you try to loosen the two bolts that are holding the factory latch and moving it upwards or downwards?
Old Jul 15, 2003
skipbarber's Avatar
you can get a car alarm with a mechanical hood lock so that when you arm your alarm it locks your hood shut.
Old Jul 15, 2003
75shot's Avatar
I <3 my Evo
75shot should not be trusted
you answered your own question. why would you remove the stock latch?
Old Jul 15, 2003
skipbarber's Avatar
sometimes you have to remove the stock latch in order to have proper fitment of your cf hood.
Old Jul 15, 2003
GreenNVicious's Avatar
Newbie
Lose the eyebrows, but those are too str8 to look like eyebrows. I dunno, looks weird with the CF hood.
Old Jul 15, 2003
the eyebrows are going just wanna get my hood on properly before i put my cf ones on.
Old Jul 15, 2003
hoievvy's Avatar
hoievvy is an unknown quantity at this point
My Hood would have the sam problem. I saw that the latch wasn't going directly in the hole for it in the hood. I just used my thumb and bent it back a little and the hood locked tight.
Old Jul 15, 2003
You bent the latch that was on the cf hood metal piece backwards?
Old Jul 15, 2003
wonderz's Avatar
removing stock latch is FlyRiceRacer02's idea. (read previous reply) That's why i asked the question the mechanical alarm sounds cool, but seems too complicated to install.
Before bending anything, you should make sure you know what u are doing. Every product might be made differently.
Old Jul 16, 2003
cdmx's Avatar
How much did you pay for it
Old Jul 16, 2003
macH's Avatar
macH is an unknown quantity at this point
all you have to do is loosen the 3 bolts on the factory latch and pull the latch up higher and re-tighten them. its not that big of a deal. it will take ten minutes tops.
Old Jul 16, 2003
Vtec02Hon's Avatar
Vtec02Hon is an unknown quantity at this point
I have installed a vented carbon fiber hood I got off ebay. And it locks in place just fine, but I went ahead and mounted the hood pins for extra safety. I would first off contact the company you purchased it from. That doesn't sound right for it not to lock in place. I am sorry to hear it.
Old Jul 16, 2003
Voiceofid's Avatar
End Bringer
i brought a new, lesser strength spring from grey, and haven't had a problem since. before, i had to close it really hard, or it won't close
Old Jul 16, 2003
Grey's Avatar
DIY King
Yeah, you need to adjust the latch and replace the spring with a weaker one. I got mine from Home Depot or Lowe's. The whole latch moves up and down. Just loosen the screws holding it down and move it up. Then tighten it back down when the hood fits properly. The little rubber stoppers also can be screwed in and out to further adjust the way the hood fits on the car.
Old Jul 21, 2003
Vtec02Hon's Avatar
Here is a picture of the hood.
Derek
Old Jul 21, 2003
75shot's Avatar
I <3 my Evo
oh my god...why did you do that to your car?
Old Jul 21, 2003
Vtec02Hon's Avatar
Why do you say that?
Old Jul 21, 2003
Grey's Avatar
DIY King
I think he means the wheels. LOL
Old Jul 21, 2003
75shot's Avatar
I <3 my Evo
ummm...yeah
Old Jul 21, 2003
Sivion's Avatar
Resident Tough Guy
Sivion is an unknown quantity at this point
Exclamation ...
Hmm, yeah kinda strange looking...Those rims on our year civic that is....Of course it's just personal preference like anything else....
EdGasket
May 25, 2015 01:06 PM
MamaBear2015
May 18, 2015 07:37 PM
cloudguy
Apr 28, 2015 05:02 AM
nymbus2k
Nov 19, 2001 07:01 AM
