Header from NOPI
Old Jul 17, 2003
jays2002ex's Avatar
jays2002ex is an unknown quantity at this point
Header from NOPI
Does anyone have this header?
And if you do does it replace the stock cat?
Old Jul 17, 2003
jays2002ex's Avatar
LINK
Its the 2nd to the last
Old Jul 17, 2003
jays2002ex's Avatar
I guess I'll be the only one to reply to this thread.
I had 1 other question.
In the DIY it said you have to shave the motor mount, but couldn't
I just use my floor jack to hold the motor then remove the motor mount
bring the header up then reinstall the mount
Old Jul 17, 2003
TunedNCivic's Avatar
TunedNCivic is an unknown quantity at this point
No, the motor mount has to be shaved a little for the header to fit.
Old Jul 17, 2003
jays2002ex's Avatar
no, I'm asking couldn't i use the 3 ton jack I got to hold the engine up then remove the mount so it will be completely out of the way?
Old Jul 17, 2003
NeonImpact's Avatar
Forum Sponsor
no, shave the mount dude..
either way it'll be one tight *** fit..
Old Jul 17, 2003
jays2002ex's Avatar
so your saying that even if I held up the engine and took out the mount it would rub
Old Jul 17, 2003
NeonImpact's Avatar
Forum Sponsor
yea jacking it up will work but once you let the engine settle back to its normal resting spot, the header will sit on the mount itself and heat that mother*** up and so forth and do some damage in the long run..
who knows, i may be wrong, but trust me, if you do everything the right way you'll get the best results..
dont be a half ***, just shave the mount some and let the motor back down and see what she does..
it shouldnt really be that hard..
but good luck!
Old Jul 18, 2003
Da1lyDr1ver's Avatar
isnt HP comming out with the same header with the same gains that does not requier you to shave anything? i heard someone say it on this site before.
UltraHDGames
Jun 8, 2016 05:16 PM
HondaGuy7
Feb 22, 2016 01:00 PM
ThatGuy913
Nov 9, 2015 06:31 AM
jdh022764
18
Nov 3, 2015 06:44 AM
anubis62
Sep 27, 2015 12:56 AM
