- Integra Airbox Conversion finished
- projector headlights fogged up
- fuel injector help
- Goy my DNX exhaust...Wht does it hang crooked??
- Good transmission?
- Ex parts on Lx
- vafcII setup info?
- Wiring Diagram for SAFC2 PLEASE!
- 2004 Mazda3 W/ Xenon - Strong At First But Fades To White...
- help w/ maintenance light
- neon inside
- Wondering about a good header
- projector headlights angel eyes
- I just got my BCII kit in
- Pillar gauge pods-Where to run wires and cables?
- Auto Tranny fluid
- Question for cam gear owners
- fuel injector flow rates
- Does anyone know where I can get an Amber OEM Foglight switch?
- DIY shift boot for a/t...
- I Need Help From Any Of The 2003 -2004 Civic Ex Lx Hxowners
- 1-2nd shift grinds on b-series
- Fender roller
- DIY rear tie bar
- OEM fogs not working....need help
- how about those parts?
- 2002 Honda Civic EX SEDAN Door Panel Removal
- My bumper is punched in... need help
- Differences between EX and HX head?
- drivetrain problems...
- 02 Si seats install?
- problems with downpipe and cat.. installation
- Installing racing seats into coupe with srs
- Spring Rate ?
- Hx to LX transmission
- Need help with Headers
- Is the exhaust size different between LX and Ex 04?
- Autometer water temp gauge?
- Freakin clutch!!! Need help ASAP!
- Should I put higher octane in my car?
- D16V1 mods?
- SRS Light on 92-95 models
- Which foglights for Xenon bumper
- EmErGeNcY!!! HELP!!!! ASPA
- Dealer says i cant reset my ECU?
- What should i buy for an exhaust
- HO2 Sensor Mod for hi-flow cats/ CEL on
- Added Boost Connect to ECU
- Styrofoam Piece Behind Front Bumper
- Gearbox Problems
- Serious info--torque specs!!
- Light Switch Assembly
- OEM brake pads break-in procedure
- What options do I have to raise my rev limiter?
- Hyper Voltage Regulator
- Easiest way to change MTF?
- Intake pipe size? 2-3-4 inch? why not?
- what is this?!
- throttle body question
- Brake bleeding order
- Clunks In Tranny Searched
- Header and Mil elim not workin HELP!
- Nology Hot Wires
- Steering Wheel
- Fuel Injector info - you can use whatever you want, as long as it fits the boss....
- painted cf hoods
- Anyone opened up a stock resonator box?
- If SOHC VTEC is made for eonomy, then why...
- Attention 04 civic
- YES There is a RECALL!
- A lil more tranny info needed..
- AWD '01 civic
- S2000 5 lug ???
- MODIFYING ECU: Is it possible for the tach to show up to 2 decimal values?
- exhaust tip too hot
- Launching my Civic
- WOW - Check out this clutch!!
- Will this catback system work on an 04 EX?
- engine problem, help please
- We have a serpentine belt i assume? and sprkplug question.
- weird knocking noise
- Help with homemade induction on 04 EX.
- Side Skirts
- Any1 know exhaust port size
- Does oil weight have any effect on VTEC engagement?
- greddy evo 2 for 04 civic
- Overfilling crankcase
- Overheated engine
- jdmb16 SiR2 pics.. finally got it
- reupholstery
- Problems with Headlight DIYs?
- JDM b16A SiR2 swap done muhuahahaa
- just orderd rsx seats and????????????
- will bomex mirrors fit sedans ??
- A-Pillar removal
- MTF plug washer?
- exhaust for 2004 civic ex coupe...
- I need the belt sizes for... **HELP**
- gauges
- DIY front strut tower bar?
- My Car is loosing power
- 0-W30 ok instead of 5W-20 in 04 EX?
- 04 Grille on 03
- Repairing Ceramic Header
- break in question
- 2004 Sedan Grill Removal
- remote start and push button start?!?!?!?
- push button ignitions stuff???
- OK. Enough $hit. WHat is the TRUTH about Engine Breaking?
- ECU Code List?
- Side mirrors wiring color?
- How do you remove the louvers in the corners on the front facia on 04 EX?
- o2 simulator and A/F gauge
- Angel Eye Projectors
- More Airbox Ramblings...
- CompuStar Security
- Check Engine Light?
- Can I remove the heat shield from my manifold safely?
- How to check air:fuel ratio?
- low end torque
- ANgel Eyes Wiring
- V-afc II ***completely Useless***
- +12 Volt Dash Lighting
- Battery wiring
- DIY for headlight
- PnP Clarification
- Header Torque Specs
- Removing hood trim
- Turbo or Bags?
- Tune up
- Pulling Engine
- Lambo doors on 2004 civic!
- Same chassis for....
- will this fit a coupe?
- SRS Light
- SAFC2 wiring diagram
- Loose seat setting off SRS??
- Maint. Light Q.
- SRS Light just came on
- Underdrive pulley's... increased milage?
- People with Bomex mirrors/ wiring experience
- RSX-S steering wheel swap completed!
- Can you buy painted bumpers?
- gauge cluster
- Alarm not locking / unlocking
- Need Help
- Increase 20 Hp
- More then one resistor???
- ac blower motor....a bit louder than usual...
- throttle body spacers
- Where to place jack stand?
- Rear Dash
- ignition system conversion
- Breaking in Motor
- Any1 have dyno charts?
- Need opinions for body work
- four on the floor
- problems with keyless entry
- Got VAFC2 - No wiring diagram, please help!!!
- Thoughts about intake manifold designs for the newer civics....
- Help Installing Wings West G5 Side Skirts
- Civic Si (Canada SIR) swap of seats
- Intake question
- unplugged egr valve
- Power Outlet accessory Mod "always ON"
- Help!! Vafc 2
- 04 civic
- transmission cooler install
- does a pulley system effect the stereo.
- Dual Exhaust On A 4 Door
- DIY on changing tranny fluid??
- ARP studs...
- ATF Replacement on a CVT tranny help
- Tranny oil??
- will AC compressor on LX fit EX?
- Can we use a different headrest??
- Problem w/ DIY Auto Locks Complete
- need help with squealing belt
- are sedan & coupe mirrors the same?
- 2K1 grill swap with 2K4 grill???
- Xenon front question?
- Rotor Resurface Question
- maint. light
- Part Swapping
- Helms Manual - which version for a 2001
- Need help with Bomex Mirrors
- port polish heads
- 02 coupe headlights
- Anyone with a rev speed meter
- Hood OEM Spec and trunk etc.
- how much $$$ for 160hp
- How to rev VTEC-E 1.6 up to 7500RPM..?
- Do I actually need torque wrench to install neuspeed strut bar?
- camshafts
- removing stock HU in 2003 civic EX SEDAN
- 98 honda civic ex
- those with greddy evo and progress
- Remote Start Problem
- safc2 install
- Magnaflow......POS
- Intake Question
- Problem with rear squeak
- evo?....
- D.I.Y. AEM cai.
- Installing side skirts??
- can I change from synthetic to standerd motor oil
- Headlights? Is it neccesary?
- 3rd gear grinding synchros ?
- Vibrate problems new exhaust
- I need help quick
- 2001-2003 Civic Recall?
- Air Bag Light
- How to install rear bumper?
- 04 front and rear bumper on 02 civic
- main brain computer of our civic..
- Side marker exact placement
- Intake swap
- will the TPS fit??
- Help!! All Keys Locked In Car, Roadside Assistance?
- help with lights
- Battery Dead?
- Need Help. Ignition Problems
- Does anyone know if our fuel injectors are Saturated or Peak and Hold?
- I need a measurement...
- DIY: Angel Eyes
- help with duplicolor or plastikote paint
- DIY-REVIEW: Ground wires and HVS! (UPDATE)
- diy oil change link
- DIY: Double Rear Turn Signal *Warning 56k Users*
- NEED HELP with shaving emblems ASAP
- how to lower the seat
- Greddy E-Manage Wiring for EX / VTEC
- Maint Req light on...help!
- cna u mold on urethane?
- torque spec for power steering pump bolt.
- anything wrong with....
- Diamondplate floor mats
- I NEED HELP, PLEASE!
- Radar Detecting Monkey!
- Car Alarm
- Grey's Kits for Revo SS
- Iridium Spark plugs causeing (audio) Engine Noise?
- Recomendations???!!!???
- Does anyone have a Kenwood KNA 2100 Nav unit? Please Respond.
- Eclipse 430cc injector do they fit
- thx for the pointers
- 2001 civic Parts List/wiring diagram
- Diy Strobes
- Mugen grounding kit
- clearing headlights
