clearing headlights
Old Mar 10, 2004
LXwes's Avatar
LXwes is an unknown quantity at this point
clearing headlights
going to try to clear my headlights, any one have some advice about the easiest way to do this and how to get the best seal again once i have to put it back together, i dont want to have to do it again to fix it. Also do i have to realign my headlights when im finshed. What do i use to seal the headlights ?
thx
Old Mar 10, 2004
Htowncivic's Avatar
Htowncivic is an unknown quantity at this point
1. No, you don't have to realign them
2. You can seal them w/ a silicone based, water-tight sealant like for RV's
3. I prefer a hair dryer to pull them apart, but an oven works too
4. Most importantly take your time w/ it and make sure you do it right, it doesn't matter how fast you get it done.
5. Also if you were thinking about painting your headlights, now is a good time to decide for or against that
Old Mar 10, 2004
JayFReaZy's Avatar
follow the DIY, it shows everything in detail. However, when seperating the headlights I suggest having a friend blow dry the edges while you pry it open, which makes it a lot easier. When you re-seal it make sure you get all the holes, you dont want any moisture getting in there. Also, make sure you do not touch the chrome parts, where the light is projected from, on the actual housing. You do not have to re-align the headlights, there is nothing to align. Just pry it open, remove the amber peice, seal it back up with silicone, make sure its dry, then put it back on the car. Good luck!
Old Mar 10, 2004
pheaton's Avatar
A descendant of 2k1civic.com
There are also metal clips that help hold it together. The clips are on plastic so when you are taking them apart be careful not to snap the plastic that they are latched onto.
Old Mar 10, 2004
BaLisTek's Avatar
i like shiny cars
BaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant future
Follow the DIY. I have pics of the way mine came out. Its really easy. Way easier then trying to pry open the OEM tail lights.
Peace
Old Mar 10, 2004
TeLLy's Avatar
Yes, it's an Acura EL
- Oven - 300 degrees for 3 minutes with coupe (be sure to remove the clips first), 4 or 5 minutes with sedan (clips integrated into headlight housing).
- You don't have to realign.
- MONO Ultra Outdoor sealant is what I use
Old Mar 10, 2004
WhiteCastle's Avatar
Read the DIY!!!! sheash another stupid post and yet I am grumpy again at your incompitence
j/k!
hope you get it done
Old Mar 10, 2004
Kloverz's Avatar
Kloverz has a little shameless behaviour in the past
be careful and take ur time
Old Mar 10, 2004
fraga's Avatar
Wicked Moderatuh
And with that, here's this. Found this while using the Search button.
Bikergofast
Detailing
Nov 20, 2015 02:34 PM
brash99
Sep 29, 2015 08:42 AM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
