Angel Eye Projectors
I recently ordered and installed a set of Sonar Angel Eye Projectors on my 03 civic. Since then I have had a few problems, 3 that I need some help with. 1) I spliced my Angel Eyes into my blinker wires (not to blink), but the splice connection is bad. I used those little blue splicer clips that you can get from like AutoZone or Advanced Auto or places like that. To get the left angel eye to work I have to jiggle the wire every time I want it to turn on, so I have it off most of the time. Any advice on splicing? I saw on another forum where someone used the crimp connectors, so they wouldn't have to unsplice in the future just in case, and thought that was a great idea. 2) Another problem I have had is with my signal/parking lights. Anyone who has bought the Sonar lights, know that other than Hi and Low beams, there are 2 more sockets for bulbs to go into. At the moment I have my stock factory blinker in the socket closest to the projector bulb, but I believe that it was supposed to go in the most outer socket(correct me if I'm wrong, because I'm not really sure). The problem is, it won't fit in the outer most socket, so what is supposed to fit there? I have heard of several people simply not using that socket, but I want to. I wanted to use the socket right next to the projector as another headlight, so I need the blinker on the outer most socket. I was going to convert it into a H4 6000K HID headlight Low beam, the projector would be converted to a 7500K HID low beam, and the high beam on the inside spot would be converted over to a 7500K HID high beam. Therefore I would have a bad *** looking row of lights with 2 blue and one pink light and then the white blinker. 3) The last problem is... The first week I had the headlights, the high beam came on with the low beam, but it was dim. Only a little dimmer than the projector though. It looked bad ***. But now, it won't do it. It only comes on when I switch on the bright lights. Does anybody know what I'm talking about with this, or experienced the same thing or knows how to make it go back to coming on with the low beams? Any ways... Thats all I really need help with at the moment... If anyone could help me out it would be greatly appreciated... Thanks a lot...
JetsterDajet
52
May 8, 2016 12:11 AM
ChrisHandHonda
26
Sep 25, 2015 11:28 PM
