Header Torque Specs
Old Mar 26, 2004
ponyman's Avatar
ponyman is on a distinguished road
Header Torque Specs
I can't seem to find the torque specs for installing a header. I need the specs for the 5 bolts to the head and the 2 to the down pipe. Does anyone have this information available?
Old Mar 26, 2004
Green Civic's Avatar
Thye head is 25 ft/lbs and the down pipe is 21 ft/lbs. I believe those are them. I cant remember. I'll look at my manual, Hames, tonight. Unless someone can verify thats correct.
Old Mar 26, 2004
AutoK20A3's Avatar
AutoK20A3 is an unknown quantity at this point
I think the header bolts are 23 ft lbs and the two spring bolts are 16 ft. lbs. I'm not absolutely positive though.
Old Mar 26, 2004
1320Racing's Avatar
1320Racing is an unknown quantity at this point
I just put in a DC Sports 4-1 header into an 01 civic and the specs for the torque were 22 ft/lb
The down pipe spring bolts should be firm since the bolt is steel.
But make sure you dont tighting one side all the way down.
Tighten each side a little at a time to make sure it doesnt leak.
And dont forget about the seals. His factory seals were in good condition. The bad part is that one of his header mounts snapped. They all call for the same Ft/lb but for some reason it just snapped, its an easy fix though.
Tedverseti
Apr 23, 2020 01:45 PM
UltraHDGames
Jun 8, 2016 05:16 PM
HondaGuy7
Feb 22, 2016 01:00 PM
rovafa2002
Sep 28, 2015 06:57 PM
anubis62
Sep 27, 2015 12:56 AM
