V-afc II ***completely Useless***
I have recently purchased and installed the V-AFC II in my 03 Civic Ex Coupe. I even wired the 'VTM' wire, which I know was left out of the original wiring manuel. At first, the engine for some reason had a big time idling and 'low cam' problem when the rpm's would jump around slightly...almost killing the engine sometimes. As long as the car was in the low cam status, it would jerk the car foward and backwards while driving as well. I called Apexi and they told me that the V-AFC II had not been tested on my car yet, and that they had no guarantees that it would work. I told them about the problem, and they had me connect the pressure signal back to how it was stock...and it started working normally again. Then just yesterday, I went to the dyno to have the car run multiple times. I hooked the pressure signal back into the V-AFC II unit to have a run w/ the Apexi, and the low cam problem mysteriously disappeared. BUT GUESS WHAT!!!...Above all of those problems, there was no room to even correct any kind of fuel/air discrepencies. The graph shows that my fuel/air is nearly perfect how it is!!! Of course, I also have to remember that I was only testing on 'Wide throttle', which does not account for some possible correction in 'Narrow throttle' like the V-AFC II allows. Just to give you an idea of what I am running...I have the V2 AEM intake, DC sport header, Megan test pipe, and the DC Sport 'Twin Canister System' exhaust. So maybe I'm being ignorant to what the V-AFC is actually used for, but from what I understand...IT IS USELESS on our cars!!! I will post all my dyno run results and car pics after this weekend!! Hope you guys enjoy them. FYI, I am getting the SF turbo kit in a few weeks...then goin back to they dyno.
~Mark
~Mark
Ur a moron. You obviously didn't install it right and you probably didnt take it to an Apexi certified tuner.
Other people on this site have seen gains of 12+ hp on their dyno tuned cars with the VAFC II.
First of all, welcome to the site.
Second, search.
There are 3000 threads on the vafc, and one that has to correct wiring diagram and tuning instructions. Heres one thread: http://www.7thgencivic.com/forums/sh...hreadid=132810
Located in the sticky section of Tech. Try to use some of the info to correct your problem.
Second, search.
Yeah, no problems here....I had it tuned with that peice of **** KMS intake manifold and it brought my torque back that I lost....Once I get the chance to get it tuned again with the stock manifold and my P&P you'll see that it is one of the best mods for your car. Why your having the problems your having, I don't know...I can tell you that you did something wrong and shouldn't try installing parts if you r not sure of what your doing
Like I said, I have already read all of the topics on the V-AFC II on this site...and the VTM wire was connected. Plus, the mechanics at the dyno shop I went to have worked with the APEXi systems before. Infact, they explained the thing to me with way more detail than I ever needed to know. Maybe I missed something...if so...let me know. I will have the dyno results posted as soon as I get back to school on sunday. If I am being ignorant to something...please kindly inform me instead of being a jackass like CarbonFly.
Ha!!!! Fly really is a good guy!!! It's just that you came off sounding like you are certain that the VAFC II is "COMPLETELY USELESS"...No doubt about it, you did something wrong, but don't worry...It will work out and you will love it once tuned and working correctlly
Alright, lets walk backwards through this.......what is your setup look like? BTW, you should keep your pressure signal connected. How hight did you set your vtec engagement?
In your situation, I would agree that it's useless. You have mods that maybe give you 5hp. The VAFCII can't be used to change anything, because your car is nearly stock. I just installed mine now and it works fine (as in no difference in performance because it's not tuned and the car is stock). Only reason I bought it is to tune the fuel when I get my ported head swapped in.
This isn't some magical mod that automatically gives you more power. Of course the air fuel ratio is tuned already on your stock car with light mods. A member here actually gained 10hp from light bolton mods and wide throttle tuning. So maybe your shop guy wasn't familiar enough with it.
gearbox...that is what they told me. They said that there is nothing major enough on my system to throw it off enough to even need correction. However, they did tell me to keep it installed because it will come in handy when I get my turbo this summer. Whoever HAS had gains using this system. I would like to talk to them. CarbonFly...I am usually very good with electronics, and I am very sure that I hooked all of the connections up correctly and securely. I have double, tripple, and quadroople checked them...especially when I was having that idling problem. Anyone here happen to live in St.Louis Missouri...Thats where I live, and it was extremely hard to find anyone who knew the company APEXi even existed. ~Thanks for you feedback guys...I'm out for the night...
Oh yeah, CarbonFly, I did not bother changing my VTEC change over points yet because they seemed to be perfect how they were to the dyno dudes. Also...I remember reading someones thread on here (I dont know if it was you or not) about our VTEC type being 1...well, I dyno ran my car on VTEC type 1 AND VTEC type 3 (which is what the manuel says for our engine) and the results were obviously in favor of type 3 just to let you guys know. Also, I did not mean to attack you w/ this thread...I guess I was just pissed that I spent so much money on something that has not prooved itself useful to ME so far.
~Peace~
Mark
~Peace~
Mark
Yeah, just wait til you get your turbo. You can always use it to monitor engine functions at least. I believe vtec=1 is the setting for our cars. Someone tried type 3 and it wasn't running well. I have mine set to 1 and it's just like stock.
was thinking about getting one, but it seems like too much work(headache) for 5 horsepower. i know that our cars don't put down alot, but damn...thanks MAPernoud, i don't think i'll waste the dough...
I live in st. louis. what county you live in i live in mehlville. Everyone always comes up to me asking what that thing is on my dash (Apex-I). It might just be the fact that my school loves muscle cars. I love my vafc II special edition even though it don't do anything yet.
VAFCII is very good if you have lots of small mods, or a few bigger ones like ported head and other engine work. You need to get it dyno tuned to see any kind of gain.
I've seen a turbo owner put down 13-14 extra hp with it dyno tuned. He's a member on here, but I forgot who he was. It's not pointless if you have a car running a lot of air flow.
K20A_Wanabe, I live in frontinac...closer to kirkwood. Friends with alot of Kirkwood and Lindberg people (sure you're happy bout that..heh). We should hook up sometime..I would like to see your car. Currently, I am still at Mizzou...but I come back to STL alot. -My V-AFC II is mounted on top of dash as well. My AIM screen name is MAPernoud...drop me a line sometime. Since I found out I have a test tomarrow..I will not be posting my dyno results until tomarrow. Peace out...
~Mark
~Mark
Originally posted by Zigen1
I gained additional 5WHP out of the safc. Cars a vtec3 ex sedan NA.
The vafc or safc's real potential will shine when paired with a turbo upgrade.
I am looking for bigger injectors and will try and use my VAFC2 to adjust back on the fuel a little. I will post results as soon as I find big injectors to fit our fuel rail..
SRT-4 owner with 2MCHPSI
Originally posted by guns
Do some research on VAFC2 and boost. When the MAP sensor is at 0pis (under boost) the fuel system is maked out. SF kit uses a Vortec FMU to push out the fuel after that point. So to make it simple the VAFC2 really does not help under boost. maybe in a return fuel setup. But w/ SF kit it does not help. E-manage seems to be a better option. Can run additional injectors, retard timing, etc..
umm your wrong there guns...once again...a vafc2 or safc2 would benefit you evern more with boost...it mainly controls your injector pulses so it would work with the sf fuel kit....i even checked with catalyst to be sure and he told me it would definately work....he recommend it...he is running a fuel/piggyback computer too....but yes...it would also greatly help in a return setup too....either way, it has to be tuned...either by dyno or wideband
What is the final word about vtec type. I and many others have vtec=1, but alot of you have vtec=3? I'm confused. I've been running type 1 for almost a month and it seems fine.
When my car was tuned, it was set to vtec 3...Keep in mind that my tuner is one of the best around....I can't tell you the differences though, because I don't know what different between the 3 vtec types
The VAFC2 modifies the signal out of the MAP sensor. After 0psi I dont understand how it would modify the signal. I was told that after 0psi the ECU is pushing the injectors at full signal.
Is there anyone who is boosted and has VAFC2 with stock injectors? If so could you tell us what settings worked good for you and if you had any problems tuning. I did some minor tuning on mine abd waiting for others upgrades before going to the dyno again.
