V-afc II ***completely Useless***
Old Apr 9, 2004
  #31
silverem2's Avatar
where are these damn dynos already
Old Apr 12, 2004
  #32
cwick187's Avatar
cwick187 is an unknown quantity at this point
Re: ...
Originally posted by Hwoody77
Hey, whoever installed your VAFC2...did you solder your wires? Or just connecting them and taped them?
You should solder all connections!!! I used wire tapes and tape and it didn't work all that great...Solder if you can!
Old Apr 12, 2004
  #33
CarbonFly's Avatar
Re: ...
YES, I soldered mine!
Old Apr 12, 2004
  #34
Philip's Avatar
Philip is an unknown quantity at this point
My buddy just used duct tape....because he can return that thing if he dosen't like it.
Old Apr 12, 2004
  #35
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
Originally posted by jwcardy
umm your wrong there guns...once again...a vafc2 or safc2 would benefit you evern more with boost...it mainly controls your injector pulses so it would work with the sf fuel kit....i even checked with catalyst to be sure and he told me it would definately work....he recommend it...he is running a fuel/piggyback computer too....but yes...it would also greatly help in a return setup too....either way, it has to be tuned...either by dyno or wideband
I found out today that you are right. w/tuning and methanol i gained almost 35hp
Old Apr 24, 2004
  #36
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
good man, glad to here that...i am headed that way to houston next weekend....alex at speed fetish is going to help me out with tuning mine...i will let you know when i plan to be there
Old Apr 25, 2004
  #37
boo's Avatar
boo
boo is an unknown quantity at this point
so wish the sf system you can tune it with a vafc or safc? can you upgrade injectors with it and use the vafc or safc to tune it? or am i completely off.
Old Apr 25, 2004
  #38
cdmx's Avatar
DYNO??
Old Apr 25, 2004
  #39
acidbaby's Avatar
The Beez Kneez
Originally posted by cdmx
DYNO??
everyone always says they are going to post up dyno's
Old Apr 25, 2004
  #40
MadWheel's Avatar
Premium Boosted Member
I had the VAFC2 on my 02 EX with stock injectors and a t04B turbo. I never dyno tuned it but I added some fuel from 5000rpms on... Mainly guess work, I would rather have it rich than lean...
Anyway, I didn't have a dyno, but with those little adjustments after 5000rpms I was able to start spinning second at 6.5psi. Now im at 6 with the new HG and no VACF2. You can tell that that thing worked. I am waiting for my emanage with all of the harnesses, that thing has quite a bit of potentional so I figured why not...
Old Apr 26, 2004
  #41
82801BA's Avatar
82801BA is an unknown quantity at this point
Never compare our 03 and 04 EX with 01 and 02 EX.
Our ECU and some essential engine internals are not the same with the 01 and 02, even though the engine model number is the same.
Old Apr 26, 2004
  #42
K20A_Wanabe's Avatar
K20A_Wanabe is an unknown quantity at this point
Really i didn't know that what is the difference? is one faster than the other ?
Old Apr 26, 2004
  #43
82801BA's Avatar
03 and 04 are having some slight improvemnet over 01 and 02. And the ECU just don't let you do whatever you want to do. I had installed VAFC-II too, and not work. The owner is my friend, he called and the result came back as it worked only if it is 01 and 02. 03+ just have too much compensation, just like, you can change the timing of valve opening, but it will also advance the ignition timing from the computer. Not good....
Old Apr 26, 2004
  #44
invasian's Avatar
invasian is an unknown quantity at this point
Ur a moron. You obviously didn't install it right and you probably didnt take it to an Apexi certified tuner.
^^ im with him.
Old Apr 28, 2004
  #45
I don't know much about it but I don't think in my opinion they would touch the motor or computer if it works fine already. Amount of money it would take them to do that.
Old Apr 28, 2004
  #46
MadWheel's Avatar
Duct tape?!?!? WTF?
Old Apr 28, 2004
  #47
Jrfish007's Avatar
The '03 models increase the timing too? I have an '03 and am think of getting this APEXi thing, but haven't heard of this different ECU thing. Why can't I just swap an 01 or 02 ECU into my car then?
Old Apr 28, 2004
  #48
I'm pretty sure the 01-04 is the same as far as engine and mechanical stuff. Only things that have changed are exterior/interior styling.
Old Apr 28, 2004
  #49
Jrfish007's Avatar
That's what I thought... but I'll call APEX in a day or two and if I have too I'll call up Honda to find out. This is the first I've heard of this idfferent ECU stuff.
Old Apr 28, 2004
  #50
Jrfish007's Avatar
Oh yeah, the only difference I know of untill '04 is the strut thing
Old Apr 28, 2004
  #51
82801BA's Avatar
What strut are you talking about?
The 03+ ECU thing....You can plug in a OBD-II reader and look at the timing...Increasing and decreasing fuel will make the timing advance or retard(I forgot which way)....If you increase or decrease fuel, the only thing that will happen when you run the dyno is.....Less power than stock.....This is not what you want to get...The 03+ ECU is just too smart to work with.....
If you have F/A with 03+ dyno, then you will notice that the engine is running very rich already(5000rpm is already 12.8).....
Old Apr 28, 2004
  #52
Jrfish007's Avatar
the struts thing... in '01 and half of '02 Honda had a strut problem with our cars as in they where blowing out, so they bumped up the size 3mm or something like that. If you buy struts for our cars, you'll notice Koni has two different sizes depending on the year, the number are barried though, but you can find it in the suspension section all over the place. Just look for a set of struts for sale, soem one will or has asked what size they are.
Old Apr 28, 2004
  #53
82801BA's Avatar
That's why I can bolt the Type-S strut directly and most people here can't, right?
Old Apr 28, 2004
  #54
Jrfish007's Avatar
It would make sences that the ECU would start to retard the timing if the A/F started going down, retardeding the timing is a way to prevent pinging associated with lean burn conditions. So then the only adavntage is with the vtec control and engine monitoring
Old Apr 28, 2004
  #55
Jrfish007's Avatar
Maybe... I've never tried that... what year do you have?
Old Apr 28, 2004
  #56
Jrfish007's Avatar
never mind... I looked at ur profile... I'm ot sure about that though, we have the bigger strut, but even the Koni's have to have a donor strut to cut up, which is why I still have my stock struts But I've not looked into type-S struts. I'd be happy with Si struts though, or naything thing that could directly bolt on.
Old Jun 18, 2004
  #57
Crackhead79's Avatar
so I still have read many threads and have no complete yes or no, does the VAFC 1 actually work or just do the VAFC 2????
Old Jul 16, 2004
  #58
82801BA's Avatar
I installed VAFC-II and guess what?
Complete stock run, 4th gear......105.8....(When I tried to make VAFC-I to work)
VAFC-II, 4000rpm, I/H, pulleys, 2 deg advance, flat A/F curve correction, 4th gear.....108.5
VAFC-II, 3500rpm, I/H, pulleys, 2 deg advance, A/F corrected to 13.2-almost flat from 3k on, 4th gear....110.0.....
That's the end of the story....
Old Jul 17, 2004
  #59
Usually tuning gives 5-10 whp on lightly modded cars. I'm gonna try and get mine tuned sometime. Every car is different. The main goal is to get the correct air/fuel mixture.
Old Jul 17, 2004
  #60
82801BA's Avatar
By the way....the temperature factor....today, 101 deg F....was told by the dyno's computer sensor
Last time 105.8, around 70 deg F.......
