Fuel Injector info - you can use whatever you want, as long as it fits the boss....
Old Apr 1, 2004
opto_isolator's Avatar
Post Fuel Injector info - you can use whatever you want, as long as it fits the boss....
With the confusion about injectors coming up - I took some pictures of the fuel injector manifold that I just purchased off of another member here. As you can see by the pictures, as long as your injector / injector o-ring is around .52" in diameter your good. Alot of the older injectors won't fit unless you do some serious modifications (such as dremeling out the boss). I believe that RC's will fit without modifications, but I will only find out when I get some (sometime!)
Boss diameter
Boss detail
Old Apr 1, 2004
civic01vtec's Avatar
looks like opto is gonna be the guiena pig
Old Apr 1, 2004
Yeah, I won't mind - as long as I can get the funds. I bought some venom injectors last december. They weren't the correct ones, so after sending them back a few times I just said to send me some for a 91-00 integra. Figured SOMEONE would be able to use them (btw, they are on ebay right now if anyone is interested)....they are peak and hold. We need saturated, or a resistor box, and I don't want to wire all of that additional crap under the hood.
I've been trying to find some used RC 370's, they are expensive new....figured used would be the way to go.
BTW - What I meant when I said you can use whatever you want - you also can't forget to get injector clips, and must make sure they are "saturated" injectors, ie they have an impedance of 10-12 ohms or so, otherwise you will need a resistor box....
docmartin14
Jul 30, 2015 11:26 AM
jackoncruzpr
May 24, 2015 12:24 AM
green01civic
Apr 29, 2015 01:36 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
