Gearbox Problems
Old Apr 4, 2004
kezay's Avatar
kezay is an unknown quantity at this point
Gearbox Problems
Ok people I have been hearing noises in my gearbox for some time so with some help
we took it down, but I MUST SAY do not try a DIY on this type of project. Our 7th gen civics
gearbox don't come out as easy as we may think. The front lower sub frame has to come out while the engine is being supported by a jack. Has anyone done this before?
Lucky for me, only four bearings in my gearbox were damaged. (2 on the diff & 1 on the high gear shaft & the last one was pressed into the case)
Old Apr 4, 2004
Jeff's Avatar
Jeff is an unknown quantity at this point
Mine is starting to have the same problems. First gear you can hear alot of noise that didnt use to be there. I only have about 18,000 miles on my sedan to. DOnt know if this will help but when we did the clutch on my friends teg, we used bottle jacks along with a floor jack to hold up the engine.
Old Apr 4, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
i just got my turbo kit on and not 2 days later 1st and 2nd gear are louder than normal. u guys think i need bearings??
Old Apr 4, 2004
C2i0v0i1C's Avatar
SuperMODrizd
i had to have all them replaced, before my turbo, it was under warranty, so i didnt care
Old Apr 4, 2004
kezay's Avatar
2k2redcivic I think that you may have the same prob. So you may want to check that out because the gearbox could lock up on you and cause death etc. because the slugs from two of the bearings (one on the high gear shaft and especially the one that is pressed into the case) could get betwen the diff!!!!! . Those two bearings don't have a cover over the slugs. The part numbers on mine were:- sx05a87ncs30 & sc05a61. Both are NTN bearings
Old Apr 4, 2004
thanks for your help. i am def going to check into it. im sure the trans isnt going to like 180-200 horse. lol
Old Apr 6, 2004
clownprince's Avatar
Ricerus Maximus
So in other words I need to pay someone with a shop to do my tranny swap, instead of doing it myself (with help)
Old Apr 6, 2004
slowciv's Avatar
slowciv is an unknown quantity at this point
how much does that cost to replace, the bearings?
Old Apr 6, 2004
Ricerus Maximus
The shop I talked to today told me it would be $250 just to pull the tranny out and put it back in, not including any kind of work/parts needed for the internals. Some transmission bearings can be pretty expensive. That's why I'm just swapping mine out. I should be able to do it (with experienced help) myself, just have to see.
Also the transmission place in town won't install aftermarket clutches.
Old Apr 6, 2004
kezay's Avatar
ok guys what I can say is that the bearings are standard bearings and you can get them to buy at any local shop that sells bearings. However the bearing that is on the high gear shaft, the inner circumference is 26mm (that is an unusual size). So what I did is take the shaft to a machine shop and have them make a sleeve to make up the space..... (I bought one that was 28mm inner circle)
It cost me $400 Trinidad and Tobago dollars in labor and the bearings cost me $60. TT for the two small ones and $99. for the two that is on the diff.
(the exchange rate is TT $6.29 for US$1.00)
If you do decide to DIY then it's gonna be a very educational experience.
CivicVoz
Apr 16, 2015 08:07 PM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
