- Will a shift knob off of an earlier year Civic fit our cars?
- 114x4
- Air to Fuel Ratio.
- slight drift...
- Lug Nuts and Focal R3's
- Need Template to cut Bumper for Fog Light ? Help
- Q? w/ 11.5:1
- Throttle cable affects MPG ??
- searched... couldnt find... clearing headlights.
- RETARD TIMING????
- Fog lights & lower grille???
- Check Engine!! light on after installing SRI..help!!!
- NOS Guru's PLEASE HELP!!
- brake upgrades?????
- Thermal Cat-Back Pics ?
- got PIAA 1700X for xmas..
- Dash Lights
- Torque spec for rear hub/drum nut?
- help and opinion please
- if i change my cai to a sri .........
- HELP QUICK!!!!!!!!
- Dynamat or other sound dampening material
- custom cat back?
- Question on DIY clearing headlights...
- ELECTRICAL PROBLM!!! PLZ HELPPPP
- Coil-over: How do you lower it?
- A few points of interest
- How do you install front emblems?
- Fender well
- NEED HELP ASAP!!!!!!!!
- Replacing Emblems...
- Straight cat/ ehaust
- springs?
- rear tie bar install
- anyone know how to do the diy hiper blinker
- Camber KIT
- tech: tie bar stresses?
- i live in queens, ny.. does anyone wanna clear my lights for money?
- Interior Strobe Positions ?
- stobe brake lights (new question added)
- more lowering help....
- DIY: Front and Rear Camber Kit Install
- Suspension Techs
- Acura (Honda) Engine Specs
- rear light bulb problems
- silicone...
- AEM Ram Air and K&N
- Help with trunk lock
- Valve Cover
- 180km/hr???
- DIY: Magnaflow exhaust install
- INJEN CAI diameter????
- h and a oil filter
- 2k1 civic ex 15"s to 99 civic lx <possible>
- defrost activation wire?
- quick question about sunroof
- Will 18's fit
- Maint req'd light???
- PLEASE HELP!!!!!!!!!!!
- Fog Light switch wiring...
- Rods/Pistons For 2001 Civic?
- Ignition System
- Forum's DIY upper grille OOC.
- Security breach? If grille removed?
- Shaving of the Emblems...
- stock wheels
- LED hoodlight hookup?
- Tightening trunk latch?
- cleaning intake filter
- Torque for wheels
- Seat swap question.
- What are fogs for ? ...
- Do you Want Blue Guage Faces ??
- Door handles
- Headers for the LX
- complete coilovers vs. spring/shock combos
- 215/45/17 and a 1" drop- question?
- Over Heating Bulbs??
- 93-2000 civic Spoilers
- 17x8 wheels?
- Bec Tech coilover system in the works
- Extention
- Question for Header Gurus
- Installing Indiglo dash.
- VTEC INDICATOR LIGHT???
- Help with clearing................
- Problem with clearing headlights??? HELP.
- Grills I got
- air/fuel ratio gauge
- DIY: Oil Change
- Engine Codes what are they
- Relocating spare tire - only on the Coupes
- Need help with LED washers
- How to remove rear stock speakers
- Push-Button Engine Starter Help!
- Some lessons on VAFC Setting Screen!!!
- Bad Shaking!!!
- Air Bag Sticker Sticky Stuff Removal
- ground control replacement parts
- Detailed insructions on Painting plug cover...
- Burning Plastic Smell
- My Headights (realign)
- !!!!!!!!!<Installing Springs>!!!!!!!!!!
- VAFC installation question
- DIY: Blue Dashlight DIY
- Questions about the 935draggers Civics, about the wheels
- coilovers dangerous?
- Tips for removing oil filter please
- Red Brake Calipers...
- DIY: Apex'i V-AFC Install Instructions
- My needles stick
- Another Steering Wheel Question
- Another Intake Question, but not which one is better!
- LED GAUGES HOW? Slickwillie HOW?
- Parking Through Drive Piece Taking Apart
- NEON RELAY PROBLEM LOOK
- clutch line?
- HOW do I relocate mY spare tire to under my trunk
- anyone know how to reset the "maintenance required" light?
- IDLE TOO HIGH???
- HX catalytic converter...same position as EX?
- Coilover problems
- V-SPEC COIL OVERS?
- My Interior Lights.......
- i dont know bout this quest.
- NOS INSTALL QUESTION HELP!!!!!
- AEM POWER PULLEY INSTRUCTIONS FOR ALL HONDAS/ACURAS
- How to remove speedometer guages?
- turn aem cai into sri?
- needle question
- clear headlights....can people on the sides of you see you're turning signal?
- removing headlights
- New exhaust and MPG1
- Want some info on CAI vs SRI?
- *Another* desperate clearing corners question...
- what fuse to put for the LED windshield washers?
- How much should I drop my car?
- Need help with 01+ Coilover w/pillow upper ball mount
- ceramic header life expectancy?
- Temperature Rating of Plastic Engine Parts
- Air coming from the vent?
- Size of windshield wipers....????
- Anyone know how to do this???
- 10,000===>maint' light...
- DIY Trim piece, the lil panel where the window buttons are.
- Self INstall or Pay to install (AEM CAI)
- Any good body shop guys out there?
- Electrical Help With An Underbody Kit
- WOULD THIS WORK
- remove the power window controls on the driver and passenger arm???
- Removing side rear panels
- Is It Worth It???
- ATTN : jaje, Question on your MB SLK side markers
- Need help on Interior trim piece removal..
- Whats the LX mid-pipe diameter?
- any such thing as a custom supercharger?
- DIY: Change Your Dashlight Color
- DIY: Installing AEM CAI
- DIY: Gas Cap Hanger
- DIY: Blue Dash Lights
- DIY: Short Throw Shift Adaptor Install
- DIY: Shutting off A/C during defrost mode
- DIY: Sidemarkers from MB SLK Compressor
- DIY: Shift Boot Replacement
