Camber KIT
Old Dec 19, 2001
Desi's Avatar
Desi is an unknown quantity at this point
Camber KIT
- which do u think is more important to fix the front or rear wheels camber?
Old Dec 20, 2001
Inspired2k1's Avatar
Inspired2k1 is an unknown quantity at this point
just get both the front is only $25 and it would be better to do none then one
Old Dec 20, 2001
ayzan's Avatar
ayzan is an unknown quantity at this point
It is more important to fix the rear because a 2 1/4 inch drop will throw the camber out +2 degrees negative camber. This will wear your rear tires out very fast. The fronts will be around 1 degree because of the macpherson setup.
Old Dec 20, 2001
0100010's Avatar
0100010 is an unknown quantity at this point
Would be best to do all 4 wheels. Most important is rear, which usually runs about $200+. The fronts are cheaper, usually less than $30 for both, so why not do all 4 wheels at once?
Old Dec 20, 2001
acura2001el's Avatar
acura2001el is an unknown quantity at this point
just do all 4 corners. Best way to go.
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
