Help with trunk lock
Guys, u know the litte lock by the drivers side which prevents people from opening ur trunk from the inside?? well i was taking out the panels that cover it to run some wires to the back and i put it back togehter and today i was trying to open my trunk but it didnt open. so i tried putting the key in and turning it but it sitll didnt no let me pull the bar, did i break the lokc or did i just put it back together wrong? can anybody do dyi to fix this? thanks guys. also, do u guys know if locking that bar should prevent the fuel cover thing from being opened too? cause i could open the fuel but not the trunk and i thought it was supposed to lock both? im confused, thanks guys!
The Standard One
i had the same problem too.. you just put it back wrong... there should be this metal part on the lock at goes into a small slot on the part thats connected to the car... it helps if both are in the unlocked position... just play with it and you should be able to fix it..
that same thing happened to me and i figured it out that there is a little peg thingy connected to the lock and if you move that you can lock and unlock it. now i know how to fix it to thats awesome! thanks a lot that helped me out a lot
fvckbg
Oct 20, 2016 07:37 PM
Sep 27, 2015 11:33 AM
aaronmechanx
Sep 14, 2015 08:45 PM
