Torque spec for rear hub/drum nut?
Old Dec 27, 2001
ayzan's Avatar
ayzan is an unknown quantity at this point
If anyone has the shop manual for our cars, can you tell me the torque spec for the rear center hub/drum nut. I will be removing my drums here shortly and I need to know the torque spec. Also, if you could scan the page for me, I would greatly appreciate it.
Thanks.
Old Dec 27, 2001
Swifty's Avatar
From: Ricemond B.C. Canada, British Columbia, Canada
Swifty is an unknown quantity at this point
I'm not 100% sure on this one but usually it's about 15 ft/lbs tightened while spinning the drum, then back the nut off about 1/2 turn and spin the drum and tighten to 15 ft/lbs again.....just don't forget the cotter pin or the dust cap.....might as well repack the bearings while youre there
Old Dec 28, 2001
rac53041's Avatar
rac53041 is an unknown quantity at this point
the torque spec for that nut is 120 ftlbs but if you want to remove your drums why not just pull them off
the rear drums are not part of the wheelbearing/hub assembly
Old Dec 28, 2001
Swifty's Avatar
good info I had never taken the drum off of mine...I didn't have it long enough
JohnnyBxo
Nov 12, 2015 03:04 PM
cukaracha
30
Jul 26, 2015 12:01 PM
hoofboy
Jul 17, 2015 04:27 PM
Jul 12, 2015 11:54 AM
SpecialRequest
Jul 7, 2015 07:52 PM
