coilovers dangerous?
Old Nov 24, 2001
KOPSEAL's Avatar
KOPSEAL is an unknown quantity at this point
I was reading an article the other day about coilovers and the way it was worded it made coilover seem dangerous. It explained the 2 typed of coilovers and the ones most people go with-i.e.300$ coilovers are very unstable and can cause dangerous handling conditions if your car is not centered right. So I am wandering, because I wanna drop my civic in december and I am scared now becaus I don't wanna blow out my handling all over some cheap coilovers and also will coilovers void a warranty? I would think so but I may be wrong. Alright thanks for any information you can give
Old Nov 25, 2001
0100010's Avatar
0100010 is an unknown quantity at this point
Well I guess improperly adjusted coil overs could cause your ride to sit unevenly, therby causing different "weight" in each corner, but as long as you keep them adjusted to about the same height, then you shouldn't have any problems. I personally have a 2 samll wood "templates", when I adjust my coil overs, I make each rear coil heght match, with the template, and each front with the other template. All I do is keep teh distance from the bottom of the spring perch the same from the bottom of the stock spring perch.
If anything, coil overs I think would make you car more stable, as you are lowering the center of gravity of the vehicle. And "cheap" 300 dollar coil overs, the only type of coil overs that are more expensive are ones that are mated with a new strut already. So it's either spend 300 on the coil overs by themselves, and then buy new struts on your own later, if your stock ones blow, or if you want them, or buy a whole set up front, either way, you still spend about 600-1000 dollars.
GolNat
Nov 27, 2018 03:32 PM
wingsfan19
Oct 1, 2015 03:45 AM
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
