PDA
View Full Version : General Honda Civic Forum Archive.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
  1. DH RACING's PNP DYNO RESULTS WILL BE HERE
  2. Will stock rear struts from a 02 ex fit on a 95 civic dx?
  3. Turn Signals Don't Work Plz Help
  4. Need help fast. My car keeps dying
  5. Help!!!
  6. D17 Wiring Pinouts
  7. windshield crack
  8. Help: Moist In The Headlight
  9. Repair manual
  10. Calculate Quarter Mile Times and More Online!
  11. Help in buying a truck
  12. STRANGE PROBLEM: Heat only works when moving.
  13. engine codes ?????
  14. signal tappin...
  15. how fast can you guys go??
  16. Rear/back license plate holder...
  17. Transmission HELP!!!
  18. Exhaust
  19. Help!!!!!! I really fu(ked up now.
  20. vtec light
  21. e-brake install
  22. removing spare tire?
  23. RSX moonroof control
  24. Best Cai Filter?
  25. Pnp Head Install Torque Specs
  26. 60,000 Miles!!
  27. Installing new Clutch?
  28. Redline limits
  29. Bulb ?'s Help Plz
  30. Maintenance
  31. where to find DIY
  32. Will New Accord V6 struts fit our cars?
  33. evo question
  34. 03+ Gauges
  35. parking light relay
  36. timing belt broke! what to do!
  37. How hard is it to mess with the upholstery?
  38. Wiring Diagrams
  39. GReddy SP2
  40. Hood shocks
  41. exhaust help please
  42. Clutch Fluid...
  43. what type of oil should i be running right now?
  44. Losing power after installing Apexi V-AFCII
  45. Is it recommended to seal TYC's?
  46. stupid question, but worth asking
  47. rev speed meter
  48. Tach Help
  49. Torque converter stall speed
  50. Universal shift knobs
  51. msd ignition wires
  52. Side MArkers Installed
  53. DIY For Tranny, Clutch, Flywheel
  54. Oil filter sizes?
  55. I have Indiglos but want to make them Reverse
  56. How to check timing on our cars?
  57. stock -> stacked internals
  58. clicking???
  59. weird sound......need help
  60. Thoughts on bypassing rev-limiter using E-manage...
  61. installing camber kit need torque specs
  62. need some one local to help me.
  63. issues with putting on rear oem lip (or any other lips) when peeling off tape
  64. Fenders from sedan...do they fit coupes?
  65. service maintenance and after market suspension
  66. LX to EX exhaust conversion, need help!
  67. Help with cleaning piston rings
  68. split fire plugs sucks
  69. question on tach wire
  70. DOT/EPA Approving
  71. driverside headlight off
  72. headlamp circuit
  73. clutch and flywheel questions
  74. Need Help
  75. Air seeping in . . .
  76. Need help quick OBX
  77. Does Mine look diff. than yours?
  78. primer difference and more??
  79. Tranny
  80. A whole shiz load of Honda manuals online..
  81. Tips for Installing a Clutch
  82. engine measurements ?
  83. best service manual ?
  84. pushbutton start?
  85. Water entering trunk!
  86. How does the sf fuel managment unit work?
  87. how do i get my cam gear off?
  88. Turning on stock alarm?
  89. how deliver more fuel to engine?
  90. How do you adjust the steering center?
  91. Stock exhaust size for EX?
  92. Best Synthetic Motor Oil?
  93. Ive searched and think I got it but maybe not?
  94. Shifter Mechanism Junk??
  95. Compression test
  96. Custom Intake Idea...
  97. LX ACT clutch fitting an EX?
  98. DH crank pulley belt measurements?
  99. Protect Your Car NOW!!
  100. the driver side (left) is lower than the passenger side (left)
  101. oem spoiler question
  102. Torque Converter upgrade help plz!
  103. WHY WOnt it Just STAY!
  104. 2004 Si Cams??
  105. Revving above 7 g's
  106. DIY: Paint Chip Repair
  107. Unsprung Weight?
  108. Exhaust Question
  109. Vertical Door Conversion
  110. Amp Problems
  111. need help on racing seat install
  112. INFO: Honda Engine Codes.
  113. Air/Fuel ratio install???
  114. Has anyone?
  115. My AIT Sensor not connected to my intake, whats gonna happen?
  116. Security System installed in DX
  117. shaving trunk lock?
  118. newb question about spark plugs
  119. Automatic Transmision Stalling
  120. How do you shield your CAI?
  121. air inlet paths in intake design
  122. Stock AUTO
  123. Vehical Warrenty's Questions!
  124. DHR RaceCams/Manifold.. is it worth it..?
  125. noticeable difference in spark plugs??
  126. sparkplugs.
  127. popping sound at high revs
  128. ecu chip ?????
  129. motor mounts
  130. automatic transmission upgrade?
  131. Need Part Number
  132. Question for Engine Light
  133. battery keeps dying
  134. How Does a Shifter using cables work?
  135. tranny gear's pops out of place...?
  136. Misfire after mods
  137. Fog light switch
  138. No interior lights, blown fuse? help
  139. RSX/Civic clutch assembly interchangeable?
  140. the link
  141. securing hood
  142. Diagram of OEM sideskirt??
  143. ignition coil
  144. 04 gauge LED temperature...
  145. what are the smptoms to a bad O2 sensor
  146. Starter Motor
  147. Coolant Leak
  148. rsx-s sway bar?
  149. vafc2 settings!
  150. small light fuse
  151. Injen RACE DIVISION CAI for 2002 civic will fit my 2003 lx c oupe?
  152. 04 gauges.....
  153. HP gains from headwork?? & Tranny Upgrade Q's
  154. clearing sedan reverse light?
  155. question about intakes...
  156. how to set a VAFCII
  157. 01-03 civic coupe parts in an 04 civic coupe
  158. 5000 rev limit?
  159. Please help with my VAFCII
  160. Header Help ?
  161. Connector for 16-pin wire
  162. SRS Light after MOMO wheel
  163. Good Temperature For Painting?
  164. Color help
  165. Aftermarket VTec?
  166. ** HELP **I've searched and searched.......
  167. how to tell?
  168. Head work real HP gain
  169. auto want go into drive unless i reset ecu.
  170. Head Swap?
  171. gauge cluster swap
  172. mounting RS/type A sideskirts
  173. Help
  174. best headers?
  175. exhaust..
  176. Changing OEM Steering Wheel
  177. help plz
  178. Door Panel Coloring, or replacing..
  179. Slanted Steering Wheel? Help!
  180. Question about PKH3-II starter wire
  181. hp gains with certain mods
  182. Reaching out for help before i go crazy
  183. Another Mid-pipe crisis
  184. interior question
  185. recarpeting the WHOLE trunk
  186. Convertible CAI
  187. 3 In 1 Fog Lights
  188. question about windows
  189. plz help
  190. dont want to spend too much...
  191. Shifting in a/t
  192. buying a catback or a muffler+custom piping
  193. dyno charts for FI and NA cars
  194. Racer Design Coilover Kit Installation
  195. Hood Pins w/Carbon Fiber Hood
  196. 2004 owners
  197. vss sensor
  198. Wiper blade chatter
  199. need a donor car
  200. compatable parts
  201. need help bad!! for aftermarket mirrors!!
  202. internal VS external wastgate
  203. hello.. can anybody help
  204. How tight should I torque 5 bolts such as alternator, transmission....
  205. o2 sensor problem
  206. Intake pipe being lead thru head light
  207. intake physics/operation crap question...
  208. Tranny overhaul?
  209. oem fogs
  210. V2 intake???
  211. spark plug swap
  212. Engine question.....
  213. Car Jack Points
  214. 2003 rear deck lid
  215. test fit spoon n1 on 7thG civic
  216. How do you switch to Synthetic?
  217. Clutch went dead!
  218. iat sensor
  219. All in one gauge??
  220. question about exhaust problem
  221. Removing Steering wheel cover
  222. N/A D17 Numbers?
  223. i bought a ebay intake
  224. HP Gain?
  225. What Helms Manual Version should I buy?
  226. Maintenance Light...
  227. Cutting your shifter down
  228. rpm vs mph chart available?
  229. tinkering around with stock intake...
  230. Changing Manual Transmission Fluid
  231. Halo Headlight burns Bulbs....?
  232. knock sensor
  233. headers
  234. broken latch?
  235. Oil Question
  236. Auto shifter mod to lock between each gear??? P, R, d, d3 etc.
  237. window washer tube
  238. tach for 2004 DX
  239. Lights behind console help pls
  240. A How-To on Shaving your emblems
  241. weight of our d17a2 w/ manual tranny
  242. Steering Wheel Emblem
  243. 2 or 5 wire door lock actuator?
  244. whole gauge panel?
  245. Quick Help Please
  246. help with mounting vtec controller
  247. gauge question
  248. VAFCII lights
  249. Quick Headlight Clearing Question
  250. DIY?: Glovebox LED Lighting
