o2 sensor problem
Old Feb 7, 2004
realitycheck's Avatar
realitycheck is an unknown quantity at this point
Question o2 sensor problem
hey guys im installing my megan racing downpipe w/ high flow cat. i cant get the second o2 sensor out of the catalyctic converter how do you get to it. i cant get a wrench in there and its just rounding the o2 sensor how do you get it off.
Old Feb 7, 2004
berettagtz117's Avatar
berettagtz117 is an unknown quantity at this point
Well I just did this 2 days ago, what I did was pull off the heat shield thats wrapped around it and then once I did that I took a good crescent wrench and put it on it and then just put some elbow grease on it and it broke loose. Other than that, that is all you can really do, dont strip it that will be no fun.
Old Feb 7, 2004
Goku's Avatar
Goku is an unknown quantity at this point
go to your local pro. shop and ask them for an 02 rench they will knwo hat ya mean
Old Feb 7, 2004
cwick187's Avatar
cwick187 is an unknown quantity at this point
Yup!!! Do that because you run the risk of stripping the nut...They make a specific tool for this like Goku said and it is inexpensive
Old Feb 7, 2004
ohmysac's Avatar
ohmysac is an unknown quantity at this point
i think autozone will even let you rent it...thats what i did...i just said no to buying one because they wanted 12 bucks for it..
Old Feb 15, 2004
chknmnky's Avatar
chknmnky will become famous soon enough
All you need is a good angle!!! Its kinda difficult and you can strip your .....nevermind. Go get the wrench from autozone. I just have a taste for the danger side of things!!
Old Feb 15, 2004
WannaBFast's Avatar
Prowlin' with a Purpose
the size for that nut is 7/8"
so just ask for a 7/8" wrench... altho you can use the o2 socket.. but whats the fun in that?
Old Feb 15, 2004
yeah thanks for the help guys i ended up just cutting 02 wires and putting a deep well socket on it, because i had to cut the wires anyway so i could put my mil eliminator on. and thanks again for the help
sharp66
31
Jun 12, 2022 08:45 AM
CarStuff
Dec 6, 2020 12:52 PM
juror
May 26, 2015 06:35 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
dooner24
Apr 14, 2015 07:51 PM
