Redline limits
as stated 100 times before, you will not gain power by increasing your redline, peak HP is around 6200-6300 RPM and you HP all after that
Back From The Banned!
Umm.... Honda put the redline there for a reason.
Unless you remap your ECU, and do some engine work, there is no point. You'll only end up running slower times, plus hurt your engine.
its true that you will not gain any HP (peak HP IS reached around 6200-6300) by increasing the redline, but the reason for revving past the redline is so that you can reliably land in vtec when you upshift. its not nearly as helpful as keeping it in lift for celicas, but might still help. although, you do run the risk of messing up your engine, and it you want to do this in an LX or DX then you're just an idiot :P
solarpunk70
Apr 12, 2016 11:43 AM
