mounting RS/type A sideskirts
Old Feb 12, 2004
Alex1's Avatar
can someone pls tell me how to mount these skirts properly. the rear mounting point is driving me insane. some said that u need to drill in the well using a 5 inch screw. some said u need a 3cm self tapping screw and drill through the quarter panel flap tha folds into the well. some said they used all the hardware that came with the skirt.
mine dint come with any hardware.
pls use pics to show me properly.
someone pls help me cuz i dont wanna drill a hole in the wrong location.
i want a clean install.
everyone with RS/type A sideskirts please show me ur rear side skirt mounting point and where u screwed it in.
thanks u sooooooooo much.
Old Feb 13, 2004
Alex1's Avatar
cmon i know im not the only one having problems like this... why dont u guys share some info and help me and help a whole shitload of other people while ur at it. ull help future people too whoever decides to have the same problem as me.
Old Feb 13, 2004
jttegx's Avatar
OMNES AD UNUM
i think tojo (tan sedan) had these. not sure.
but i have a coupe and have the oem side skirts and rear lip.
for the sides: 2 screws on both sides. cant remember how long they are but my guess is around 1.5 inches in length. but BEFORE screwing anything in, id suggest u get another buddy becuz what u have todo is get sum double-side tape (3m) from kragen/autozone/your local auto supply and place the double side tape in-between the side of the car so it lines up properly. for the tape... i used 4 pieces total, 2-3 inches long a strip. oh btw, i didnt use 3m tape, instead i used double-side adhensive tape which was sticky foam tape. mine was required to take out the rear tires so theirs room to place the screw in the proper hole but no, instead me and donnel (who sold it to me) just made a new hold for the sides by the rear tires.
rear: on my oem rear lip, their were 4 screws too i believe. 2 on each side behind the rear tires. and same procedure as the sides with the tape and all that work.
but since u have a diff set of lips, i think it would be different becuz mine is all oem fit n more easy.
hope this helps u out.
Old Feb 13, 2004
alloriginal's Avatar
putang inamo!!!
alloriginal is an unknown quantity at this point
i didn't really get the question, you said you want to know how to mount the rear part of the RS sideskirts? mine didn't come with any hardware. i just drilled a hole and screwed it in, their was suppose to be mounting brackets with the sideskirts but i didn't use it. you don't really need it unless your always scrapping. hope this helped =)
Old Feb 13, 2004
Alex1's Avatar
where did u guys drill it in the wheel well? was it on the quarter panel edge that flaps over the well or was in the well itself?
Old Feb 13, 2004
jttegx's Avatar
OMNES AD UNUM
hmm, dunno what you are talkin about their but ill show u a pic(s) of mine when i install my coilovers. thats around next week... but dont rely or count on me.
be more specific. =\
Old Feb 14, 2004
putang inamo!!!
Fit the RS sideskirts left OR right, straighten it out and you should be able to see where you're rear sideskirt should be drilled in. You're sideskirts should have pre-drilled holes on the rear, some don't. If not then check out JDMCIVIC or 2002EM or PecX's pictures in the members rides.
Old Feb 14, 2004
Alex1's Avatar
^ dumbass... get the hell out of my thread u herb!
Old Feb 14, 2004
putang inamo!!!
you're very welcome you ***, be more specific when you ask things. im not even gonna argue over online with you...
Old Feb 14, 2004
Alex1's Avatar
^ stop whining and get the hell out herb
and by the way, "i did not thank ur dumbass"
mgrantaz
General
May 2, 2022 05:40 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
twd000
Oct 4, 2015 12:52 PM
jackoncruzpr
Sep 29, 2015 07:59 PM
FistRock
Sep 4, 2015 08:00 PM
