60,000 Miles!!
Old Mar 7, 2004
charlios's Avatar
charlios is an unknown quantity at this point
60,000 Miles!!
Hey guys, I just hit 60,000 miles. I never went had any maintence done beside the usual oil change every 3000 miles. I did replace sparks plug at 45, 000 and had transmission fluid changed at 45,000 as well. What kind of maintence should be done at 60,000 miles?
Old Mar 7, 2004
DUBjr's Avatar
DUBjr is an unknown quantity at this point
You should be getting into timing belt and water-pump replacement mode.
Old Mar 7, 2004
sakabatou's Avatar
sakabatou is an unknown quantity at this point
Civic Maintenance Schedule
Your next scheduled maintenance is: 64,000 km or 32 months
Type C
Replace engine oil* and filter.
Service front and rear brakes.
Rotate tires**, inspect for wear and adjust pressure.
Lubricate all hinges, locks, and latches with multipurpose grease.
Inspect tie rod ends, steering gear box and boots.
Inspect suspension components.
Inspect driveshaft boots.
Inspect parking brake adjustments.
Inspect brake hoses and lines (including ABS).
Check all fluid levels, condition of fluids, and check for leaks.
Inspect cooling system hoses and connections.
Inspect exhaust system.
Inspect fuel lines and connections.
Check all lights.
Inspect the underbody.
** Tires may require frequent rotation
dependingon driving conditions, alignment
and driving habits.
Specific Additional Required Maintenance
120mths/192k & then every 60mths/96k Replace Coolant
96,000 km & 48,000 thereafter Replace Automatic Transmission Fluid
Every 96,000 km Replace Manual Transmission Fluid
Every 36 mths Replace Brake Fluid
84 mths/176,000 km Replace Spark Plugs
Every 96,000 km Inspect Spark Plugs, Lubricate Threads and Replace if Necessary
84 mths/176,000 km Replace Timing Belt & Inspect Water Pump
100,000 km Replace Timing Belt & Inspect Water Pump if regularly driven in very low temp (-29 C, -20 F)
84 mths/176,000 km Inspect Idle Speed
84 mths/176,000 km Inspect Valve Clearance, adjust if noisy
My car is not even 2 years old it already has 50,559km
I do my regular oil change and check my fluid level and that's it. The only thing that I will have to get service is my rear suspension. When you reach 100,000km then you will have to do major maintenance.
Old Mar 8, 2004
bhaz413's Avatar
Support your local 81
From: In the land of milk and butter, Massachusetts, US
bhaz413 is an unknown quantity at this point
Re: 60,000 Miles!!
read the manaul, but i have 118k miles on my honda. All I do is change the fluids and follow the manual.
Old Mar 8, 2004
lberry's Avatar
lberry is an unknown quantity at this point
I am right behind you with 59,000. I already changed the plugs and I cleaned & oiled my K&N filter.
I plan on changing the Brake fliud/clutch fluid, Manual trans oil, Cabin filter, and regualr Oil change. (myself)
Also throwing on some Energy Suspension control arm bushings (mine are shot). Needless to say this is going to be a very busy Saturday.
Timing belt and water-pump don't need to be changed until 100,000 or more.
If you have not at 45,000 you might want to get a valve ajustment.
Old Mar 8, 2004
lberry's Avatar
Oh yeah, forgot about the fuel filter.
Old Mar 15, 2004
lberry's Avatar
Actually I was wrong about replacing the fuel filter.
Did you guys know that our cars have lifetime fuel filters.
I went to the local Honda Parts Dealer on Saturday to try to pick one up and they told me you never have to replace it unless you have to flush the fuel system for bad gas. Oh well saved me some $$
Just thought I would share this info if anyone was wondering.
Old Mar 15, 2004
02civicricer's Avatar
The Rice Machine
02civicricer is on a distinguished road
60,000 mi/96,000 km Scheduled Maintenance
Rotate tires (follow pattern on page 164 of your owner's manual)
Replace air cleaner element
Check oil and coolant at each fuel stop
Check tire inflation and condition once a month
Source
Old Mar 16, 2004
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
the timing belt shouldnt be replaced till around 100,000 miles and the a/c and alternator around 60,000 per honda.
Injen
Old Mar 16, 2004
CivicsRdBest's Avatar
Hmm... I'm @ 56800(Just this morning) so I will be there soon...
how much does all that stuff cost? I'm probably going to need a new set of windshield wipers and a new air freshener too...
mattdoc
Mar 14, 2017 12:10 PM
jordan1794
Jun 11, 2015 09:14 PM
mrohitredd
May 28, 2015 10:03 AM
sccarally
Texas
May 17, 2015 10:11 PM
Fatbastard
19
Feb 16, 2002 10:24 AM
