popping sound at high revs
Old Feb 18, 2004
corbeaucivic2nr's Avatar
corbeaucivic2nr is an unknown quantity at this point
ok just recently if i shift above 5 grand in first and i hear a pop/cracking sound, it never did this also i shift from 5th to 3rd at appropriate speed i here it. i hope its the clutch and not the tranny, anyone else had this prob?
Old Feb 18, 2004
WhiteCastle's Avatar
clutch.
Old Feb 19, 2004
thanx but check this out i had to change my air fileter today and i saw my intake was loose so i tighten it and it didn't do it, then later it did it again then stopped. i puzzled on this one
Old Feb 19, 2004
7thGenerasianCivic's Avatar
maybe it is something around the intake? since you fondled around the intake area and it stopped... check around for loose parts or whatnot.
Old Feb 21, 2004
it started again. i'm stuck. i have no clue so i'm gona go ahead and change my clutch
Old Feb 22, 2004
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
I might be way off here... but a while back some people were talking about having a popping sound when they shifter, and it actually ended up being the filter on their intakes. Also make sure that the piping isn't all the way inside the filter.
Worth it to at least check it out if anything
Old Feb 22, 2004
civic-king's Avatar
civic-king is an unknown quantity at this point
any exhaust work done?
you might have a leak in your exhaust, loss of back pressure, causing a rumble or "pop." check exhaust flanges.
Old Feb 22, 2004
silverem2's Avatar
do you have a strut bar??? I had one that almost was hitting the intake but didnt, and every time i would hit high rpms, it would hit up against there. Your intake does move, so check that.
Old Feb 22, 2004
ViNRoCk8's Avatar
#1 S2000 Fan
Off-Topic: Civic-King your avatar is the ****!
Old Feb 22, 2004
civic-king's Avatar
....i like drugs.....
...funny though, i don't like illies
GolNat
Suspension DIY
May 12, 2022 06:49 AM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
Kaelin
Jun 19, 2015 04:19 PM
B1zZ
Bolt-on Engine Performance
Jun 2, 2015 11:42 PM
reqy
Jun 1, 2015 07:05 AM
