rsx-s sway bar?
Old Feb 15, 2004
CivicS's Avatar
CivicS is an unknown quantity at this point
rsx-s sway bar?
i'm going install that RSX-s 19mm sway bar soon, but which one should i use to left up my car: ramp or jack stand?
i think if i use ramp, is that means all the forces on the rear tires is pushin up, so make it hard to take off the stock sway bar? or i needed to use the jack stand to free up the tire in air for easy take out?
anything to look out for?
need ur help, thanks
Old Feb 15, 2004
WannaBFast's Avatar
Prowlin' with a Purpose
i would put that up on jack stands.. its easier when both wheels have "slack"
Old Feb 15, 2004
berettagtz117's Avatar
berettagtz117 is an unknown quantity at this point
Just lift the back end up and put each side on jack stands, it is a easy process took less than a hour to do mine.
Old Feb 15, 2004
WannaBFast's Avatar
that is.. unless u gotta cut the endlinks off.. then u gotta wait a while before u get gray's custom endlinks...
my advice.. have lots of pb blaster handy... soak the endlinks for at least 2 days before attempting to remove them from the sway bar/control arm
Old Feb 15, 2004
thecheat's Avatar
thecheat is an unknown quantity at this point
use jack stands and take your wheels off, tons more space and light. The DIY for the progress rear sway and mounting is a really good referance. Shouldnt take more then an hour if you have all the parts. Did you get RSX bushings?
Old Feb 15, 2004
pnoyster2k1cvic's Avatar
Balut Eating Champ
any of ya'll got a picture of the finished upgrade? I might do it to my Cvic!
Old Feb 15, 2004
civicvtec1ps's Avatar
Search and Learn
http://www.7thgencivic.com/modules.p...howpage&pid=75
DIY
http://www.xenja.com/7thgencivic_RSX..._DIY/index.htm
Sway bar Specs
http://www.sceniccityonline.com/arti...ybarspecs.html
Old Feb 15, 2004
CivicS's Avatar
i just got the sway bar with bushings.
well, i dont have 2 jack stands, but i got 2 ramp....is that oky, if i use ramp instead of jack stands?
so which is easier, take out 2 endlink or just endlink bolts?
thanks everyone input.............very appreciated ur help.
Old Feb 15, 2004
thecheat's Avatar
I think it will work just fine with ramps, just alot easier if you can get the wheels off. Just unbolt the endlink from the sway bar. It has a nut on it and the end of the bolt is an allen, if that makes any sense. So you put an allen in the end to hold it still and turn the nut with a wrench. All this is in the DIY. If you live in Chino and you havent been driving in snow or lots of water, the bolts should all come out no problem, mine did. Just grease them well when you put them back on. I had a friend of mine help me so we could do the endlinks and everything from both sides, having the extra set of hands and eyes really made it easy.
Old Feb 15, 2004
WannaBFast's Avatar
nuff said
Old Feb 22, 2004
CivicS's Avatar
i just installed rsx-s 19mm sway bar this saturday, my car is lowered with tein basic, no finger gap at rear, after installed the bar i noticed my rear raised up like 1 inch high ! i belived i installed it right, cuz i checked that DIY site. but is this normal for all peps who installed these bar?
thanks,
Old Feb 22, 2004
WannaBFast's Avatar
did you use ramps or did you install on jacks?
cause if you installed on jacks, you should just wait a few weeks to let the rear settle
Old Feb 22, 2004
ViNRoCk8's Avatar
#1 S2000 Fan
Has anyone installed the DC5-R 22mm bar?
Old Feb 22, 2004
CivicS's Avatar
i installed on jack stand, 1 on each side......i needed to wait for settle. nobody mention this before or for lower car only?
thanks,
SammySC
121
Apr 7, 2017 07:43 PM
Raiool
Oct 1, 2015 10:42 AM
rovafa2002
Sep 28, 2015 06:57 PM
beanhead
Sep 24, 2015 12:04 PM
Viczhou
Sep 2, 2015 07:55 PM
