i bought a ebay intake
Old Feb 4, 2004
johnovan's Avatar
I usually put a cucumber in my bum when I jerk off!
johnovan is an unknown quantity at this point
i got a intake and all i have to do is take the 2 air filter boxes out and install mine right?
do i need a bracket?
thx
Old Feb 4, 2004
import2nr's Avatar
awd pwnz j00
welcome to the site man.there is a DIY for a AEM intake, its the same type of intake u have. just follow that.
Old Feb 4, 2004
importuner86's Avatar
importuner86 is an unknown quantity at this point
It's an easy install
Old Feb 4, 2004
sCoTtEh's Avatar
sCoTtEh is an unknown quantity at this point
it shouldent be too hard, just check out the diy on the side of the screen
Old Feb 4, 2004
johnovan's Avatar
im using a short ram, any steps i can leave out?
Old Feb 4, 2004
7thGenerasianCivic's Avatar
once you get started it's REALLY easy dude. The bracket should be welded of whatnot to your intake tubing.
Old Feb 5, 2004
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
all that stuff about taking off your bumper is unneccesary. Just take off the resonator and filter box and bolt up your sri and you'll be fine.
Old Feb 5, 2004
FuzzBeC00L's Avatar
Fuzzy Boy
Welcome to the site bro Hope everything goes ok.. Later
Old Feb 5, 2004
mootlif3's Avatar
mootlif3 is an unknown quantity at this point
Just bought one off of there last night also. It looks like it might take around 15-20 minutes to put on, nothing too hard .
Old Feb 5, 2004
tripledoublegs's Avatar
Euro-Spec
It'll take you a bit more than 15 minutes, but definately less then 2 hrs if you have experience.
Old Feb 5, 2004
MadWheel's Avatar
Premium Boosted Member
try about half an hour. i've done 2 diff ones on mine, one on my friend's 7thgen, and one on my gf's 7thgen lol...
u need a 10mm socket, a long extension, and a ratchet of course.
Taking out the resonator first (along with the lil tube that goes to the left) is the first thing to do. Also keep in mind that there is a screw (look at the throttle body from the driver's side of the car) that holds the air filter assembly to the throttle body. Loosen that before you attempt to pull the final box out.
Putting the aftermarket intake on is a breeze once you've taken the stock one out. Good luck.
Old Feb 5, 2004
cryption's Avatar
2003 Nissan Frontier
rofl I'll be the first to say search =P
welcome to the site
Old Feb 5, 2004
jwalker87's Avatar
Bodacious Member
the hardest part is getting the filter box off of the TB...because I didnt know there was a band that was screw-tightened around the TB...
Old Feb 5, 2004
opto_isolator's Avatar
Hahaha - I just installed one of those $30 ebay intakes last week sometime. For $30 it works - but its quality is to be questioned. The parts that came with the intake were a joke - there is no flange welded to the intake pipe to bolt to the engine block, so my intake pipe is only being held up by the silicon hose clamp to the TB.
The filter didn't come with a 3" hose clamp to clamp it to the intake pipe, nor did the valve cover hose fit properly (I had to ghetto rig it). BUT it works (and it was shipped really fast too!).
The only reason I installed one was because I am installing a turbo and need the room to convert my fuel system (the airbox / filterbox take up a LOT of space in the engine bay!)......
Old Feb 5, 2004
jwalker87's Avatar
Bodacious Member
my RD intake doesnt have a bracket either. THe CF shroud attaches to the front radiator support...thats all that supports it.
Old Feb 5, 2004
johnovan's Avatar
thanx for the help, i tried seraching but i wanted something detailed, and i'll get to it sunday with help from my friends
i'll tell ya how it goes...
btw, i have a few dings on my car..like 5..6... how much do you think it would cost to fix those? i want it clean
Old Feb 6, 2004
dings like dents? buy the ding king
if not and it's like paint chips then $$$
Old Feb 6, 2004
kingrice's Avatar
kingrice is an unknown quantity at this point
I bought one about 3 months ago off e bay and it didn't exactly fit right I had to do some slight mods but now its awsome
Old Feb 8, 2004
johnovan's Avatar
alright i got it done and my lord it saved alot of fucn space...first the stock filteres was..huge, and the only trouble i had was that the rubber fittin didnt fit, so i had to use the stock placers(filter>throttle) and put it inside my rubber fitters,..worked fine, but when i stop it would shake horribly, that scared the crap outo f me, but i waited 20 mins in idle and everything was fine again, no performance increase, but sounds good and loud
Old Feb 9, 2004
kingrice's Avatar
Thats about what happened to mine. Not much power but sounds mean and looks nice.
Old Feb 9, 2004
thecheat's Avatar
thecheat is an unknown quantity at this point
I got a $20 one too, very slight top end increase but not much. You might want to check the filter for oil, mine wasnt oiled when i got it.
Old Feb 9, 2004
johnovan's Avatar
what do you mean oiled?
am i suppose to do something with that?
Old Feb 9, 2004
MadWheel's Avatar
They sell filter oil. It's usually a pinkish/redish color. If you have a steel filter, non-oiled, you need to buy K&N or AEM etc filter oil and lube it up!!! Without the oil the filter will not perform properly.
Old Feb 9, 2004
bickford05's Avatar
bickford05 is an unknown quantity at this point
it shouldent take you very long.. good luck
Old Feb 10, 2004
johnovan's Avatar
is it absoluetly neccesary to lube it???
Old Feb 10, 2004
jwalker87's Avatar
Bodacious Member
mm...lube it up
Old Feb 11, 2004
johnovan's Avatar
what type of oil is it? i went to oriellys and they laughed... where can i get it? and whats it called, tahnx
Old Feb 11, 2004
thecheat's Avatar
Tell them you want a "K&N filter recharger kit", it comes with everything you need and really good instructions. If yours is like mine then the filter will be red even when its clean (real K&N filters are white so you can see the red oil on them and know when they are oiled), so use the metal strip to keep track of where you started. it all comes in a lillte orange and black box with some red and a graph paper pattern on it. What the heck is an "oriellys"? Is that like a pep boys or autozone? Im just currious about that part cause I have never seen one out here in CA.
Old Feb 12, 2004
johnovan's Avatar
is it bad that i ddnt use oil in a week?
Old Feb 12, 2004
jwalker87's Avatar
Bodacious Member
eh... i didnt use oil in like 6 months
