Coolant Leak
Old Feb 15, 2004
civicstylz4u's Avatar
civicstylz4u is an unknown quantity at this point
Angry Coolant Leak
I have been hearing a “water fall sound” coming from the passenger side dash, sounds like there is air in the coolant lines. I went to a carwash today, and when I came out all my coolant had leaked out and was all over the road. It was coming out near the wheel well (passenger) and some even on the driver side. Now there is no cold or hot air coming from the vents. Can you believe that my car only has 10,000KM, 2003 SIG. I thought Hondas were good cars? Any one knows what this might be, or do you know of anyone that this happened to?
Old Feb 15, 2004
Da1lyDr1ver's Avatar
did your car overheat? if you car's temp gets hot enough then coolent will spew out of the radiator to the reserve tank, and if that gets too full then it'll flow out of a tube onto the ground. check if your car is overheating. it might be as simple of a fix as a thermostat.
Old Feb 15, 2004
Coolant
No the temp was sitting between C and H. Higher then normal, I looked and all the coolant is gone. The Honda Dealership is only 1 km from home, I am going to take it in, I also need to get my driver chair fixed, it rocks
Old Feb 15, 2004
WannaBFast's Avatar
Prowlin' with a Purpose
if the chair rocks, why get it fixed? heheh bad joke.. but yea, have it checked out for leaks and stuff
oh.. i thought they got the rocking chair fixed in 03?
Old Feb 15, 2004
7gen03's Avatar
7gen03 is an unknown quantity at this point
this ones a no brainer cars new 2003 TAKE IT IN its covered plus rocking chair syndrome is normal but if you stay on there ***(the dealer) they will replace the track
Old Feb 15, 2004
GreenNVicious's Avatar
Newbie
The best thing you can drive your car over to your local Acura dealer and get a RSX-S
cukaracha
30
Jul 26, 2015 12:01 PM
Bounddyy
Jul 8, 2015 11:22 AM
ZILLA
Jul 5, 2015 05:24 PM
Causemo
Jul 5, 2015 06:42 AM
Causemo
Jul 4, 2015 07:11 AM
