Revving above 7 g's
Old Feb 22, 2004
hooter73mc's Avatar
hooter73mc is an unknown quantity at this point
Revving above 7 g's
What do I need to make my EX rev above 7 g's aside from a valvetrain upgrade.
Old Feb 22, 2004
Zzyzx's Avatar
Autocross Junky
^^ why? ^^ unless you have extensivly altered the torque curve theres really no reason to go past redline.
Old Feb 22, 2004
Well, assuming there is a way to remove the rev limitor, it would only cause engine damage anyway.
Old Feb 22, 2004
hooter73mc's Avatar
THANKS FOR THE HELP!
Old Feb 22, 2004
hooter73mc's Avatar
I am rebuilding another engine soon with all DH Racing parts and I just wanted to know how to remove the rev limiter and all the electrical side stuff. I know the results of over revving and I don't need to be schooled there, it's common sense, but when it comes to the ECU and all I do need a little schooling
Old Feb 22, 2004
hooter73mc's Avatar
if you're not going to help me out on this issue or don't know how then please don't post.
Old Feb 22, 2004
cambo's Avatar
I wish I was asian
well no one knows how to yet. No one has been able to change the limiter.
Wait. no. actually i think Jet can do it. But they cant take out the speed governer.
Old Feb 22, 2004
hooter73mc's Avatar
What about getting an older ECU, is that an option? if so what else would I need to make the ECU work with my car?
Old Feb 23, 2004
cambo's Avatar
I wish I was asian
no. cant do that. Your car will either run like **** or wont run at all.
And if you did try to use an older ECU, you'll be spending way too much time and money than trying to reflash your current ECU.
Old Feb 23, 2004
AzNmiKex215's Avatar
2k1civic.com O. G.
you neeeed altezza tail lights.
Old Feb 23, 2004
hooter73mc's Avatar
altezza's huh...*****!!!
Old Feb 23, 2004
CivicsRdBest's Avatar
Why do you want to rev that high in the first place?
Old Feb 23, 2004
Zzyzx's Avatar
Autocross Junky
There seems to be this thought floating around the import scene of If you can rev the engne higher that should give me more power/accleration. Unfortunatly its wrong. (Though it would be nice if it were true) See, power and acceleration is baised on the torque curve of a given engine, and as described its a curve. Meaning it has a peak and then drops. so a given engine, Folowing its torque curve, will make more power till its peak and then start to make less power, as the engine starts to make less power, there will be a point where the engine is making the same power as it would be at a lower RPM in the next highest gear. That is your optimum shift point. Where is that on our cars, well I dont have a Dyno to tell you. But I can say that its probably only a few hundred RPMs past peak HP (6300 on the EX, 6100 on all others).
So, Like I said before, the only reason you would need to change the redline on your civic is if you have Extensivly changed the torque curve of the engine. and even then you'd need to dyno your car to find the optimum shift points.
Old Feb 23, 2004
civic01vtec's Avatar
he's absoulutely correct..........our motors start losing power after 6300-6400 rpms.......there is no reason to increase the rev limiter past 7000 rpms.
Old Feb 23, 2004
Renamazazo's Avatar
Renamazazo is an unknown quantity at this point
Since I have an HX, I typically will REV 1st all the way up too 7K, that way I start in the next gear higher up and closer to the power, cause If I shift at 6500, that'll drop me down to 3250 in 2nd gear, which is fairly low, so I typically rap it all the way out in 1st, so I can be as close to 400 as possible
Old Feb 23, 2004
Zzyzx's Avatar
Autocross Junky
^^ true, Shift points are also influenced by gearing. wich is the problem you are runnin in to. Too tall of gears, great for gas milage, bad for acceleration.
Old Feb 23, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
I too would like to change my rev limiter to ...say ... 8000. That would be nice. The idea is to get a reground cam and to change the limiter to 8 so I would have a better top end with all my gears
Old Feb 25, 2004
hooter73mc's Avatar
Now people are starting to see it my way lol. I want to rev that high so that when I shift into 2nd I don't drop out of Vtec.
Old Feb 25, 2004
Jodster's Avatar
Post Whore General
The ECU is whats limiting you from reving high. No one make a program yet that raises the rev limiter on the D17 ECU. You would have to built your valve train to hold up anyways. Plus you would need to dyno tune the car to make any power above 7K. You could try to get ahold of Hondata and see if they will do a custom reflash for you. One of these days some one will make a new ECU for us. Also, you can not use a older ECU. Because of the immobilizor(SP?) We have on our ECUs. You might be able to get an older ECU you work if you by pass the immobilizor. But then I don't know if the fuel maps on an older ECU would be the same as ours.
Old Feb 25, 2004
Zzyzx's Avatar
Autocross Junky
VTec isnt nearly as important as you seem to think it is, especially in our cars. Like I said you need to look at the torque curve and that will tell you when is the best time to shift, Vtec or not.
Old Feb 25, 2004
pheaton's Avatar
A descendant of 2k1civic.com
Yeah, the vtec in our cars is mainly for fuel efficiency during high revs. Doesn't do much at all.
And going on what Zzyzx said earlier about the power. I can tell when I'm driving that after 6000 the car is done until I shift. It doesn't have much of anything after 6000.
You can almost feel that optimum shift point, it's that point where you can feel the car stop pulling you back into your chair. .
Old Feb 25, 2004
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
I belive the vtec system is a 3 stage vtec
Old Feb 26, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
^^ that may be, but isnt the goal still fuel economy and emissions?
Well, I think the only solution here, engine swap! K20
Old Feb 26, 2004
cambo's Avatar
I wish I was asian
k24!
Old Feb 27, 2004
AlienX's Avatar
AlienX will become famous soon enough
after 1st, vtec always stays on... and EX has no speed govener.. about the rev limiter, you need to get the ECU flashed...
Old Feb 27, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Getting a cam and valvetrain upgrade will allow you to make power at higher rpms.
Old Feb 28, 2004
hooter73mc's Avatar
That's pretty funny cuz the dyno I have show's the highest amount of power at 6200
Old Feb 28, 2004
Zzyzx's Avatar
Autocross Junky
^^ yes, but how quickly does it drop off after that point?
as in whats your Torque and HP at 7,000 RPM and where else does the car make those #s? (in lower RPMs)
Old Feb 28, 2004
dupes1983's Avatar
dupes1983 is an unknown quantity at this point
aaaahahaha NO
hmmmm once again aaaahahaha NO
Old Feb 28, 2004
Merciless's Avatar
Merciless is an unknown quantity at this point
Why dont you just get a Vtec Controller??? Those work on the newer cars don't they?
