what type of oil should i be running right now?
Old Mar 4, 2004
R3DL1N3's Avatar
i recently got an oil change and put some 5w20 castrol in and its kind of running a little shitty. should i be running anything different?
Old Mar 4, 2004
hothondacivic02's Avatar
hothondacivic02 is an unknown quantity at this point
I dont think it cause of the actuall oil since that weight is what supposed to go in there it even says in your owners manual maybe you didnt fill it up have you checked the oil since you did the oil change .
Old Mar 4, 2004
R3DL1N3's Avatar
im not the one who did it. and no i havent, im going to go check it as soon as i get out of class.
Old Mar 4, 2004
WhiteCastle's Avatar
ya just check, im running synthetic...
Old Mar 4, 2004
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
i have no clue what the hell i use all i know is that its 5w20 valvoline.
at least thats what it is when i change it myself instead of honda. but i think they use the same at my local dealer.
Injen
Old Mar 7, 2004
03white5spd4d's Avatar
03white5spd4d is an unknown quantity at this point
Re: what type of oil should i be running right now?
can you give us some more information. where did you get your oil changed? only think i can think of is to much oil was used, its a long shot but check your oil level.
Old Mar 7, 2004
notoriouspyro's Avatar
Crack kills... But then again... So do I...
notoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the rough
Don't start changin your oil around. If you have been using 5w-20 for a while now, you run the risk of crackin your piston heads.... And above all... DO NOT SWITCH BACK AND FORTH FROM SYNTHETIC TO REGULAR OIL..... 5W-20 is a real good grade oil, so I don't really think that this is the source of your problems.... But best of luck to you in anything you decide to do....
Old Mar 7, 2004
they only problem you end up with switching from conv to synthetic is when you do it on high mileage motors. the cleaning properties of the syntheitc oil actually clean up the deposits so good, you can start leaking oil. even though the synthetic oil manufacturers deny this, i know of a few ppl who this has happened to. other than that, no biggie. i agree w/ stpryo8, either commit to synthetic or stick w/ conventional. who or where did you get your oil changed?
Old Mar 7, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
Re: Re: what type of oil should i be running right now?
Hmm... I over filled on oil once and it was fine.
Old Mar 7, 2004
Re: Re: Re: what type of oil should i be running right now?
happy it worked out for you. trust me on this one overfilling oil is not a good practice. some ppl have known to do this and it really hurts the motor. next time you go and get your oil changed, asked the tech and they will tell you how bad it is. i know it might sound like but as the saying goes, more is not always better.
Old Mar 8, 2004
^^^ I agree, I did it by accident, basically there was a long story behind it. I would never do it again!
Old Mar 9, 2004
VTEC01EX's Avatar
VTEC01EX is an unknown quantity at this point
5W-20's what you're supposed to use. Unless you were using crude oil, I really don't know how changing oil could result in an engine running that differently. It's more about providing adequate protection. However, I do have friends that claim their cars run way better after oil changes. Of course they run the same, it's just a mental thing.
Old Mar 11, 2004
streetglower's Avatar
just one question, usually I buy 4 quarts of oil, do most of you, like me, pour all 3 bottles in, and then pour in about 3/4 of the fourth bottle?
Old Mar 11, 2004
sw388integra's Avatar
when it's cold outside, i run 0w-20, and when it's hot i run 5w-20...mobile1, nothing else
Old Mar 11, 2004
when i change my oil, mobil 1 bottles have a side that is partially clear so you see how much is left. i love working on my car, but why does honda have to hide the filter and point it up. i just change my oil the other day, walmart carries a 5 quart bottle for 19.72
Old Mar 11, 2004
that doesnt answer my question though, do you pour in 3 bottles and then like 3/4 of the last bottle. on mobil 1 bottle it is hard to understand.
Old Mar 11, 2004
i pour in 3.5, then add to fill using the dipstick as a guide.
Old Mar 11, 2004
i use a little more than that, but oh well.
Old Mar 11, 2004
as long as you dont go over 4 quarts, its ok. more than that and your risking head damage
Old Mar 11, 2004
I figured that.
Old Mar 11, 2004
bluericeburna2k2's Avatar
bluericeburna2k2 will become famous soon enoughbluericeburna2k2 will become famous soon enough
well u cant check ur oil level while the front end is jacked up. i always change my oil at night so i let it drain overnight to get all that old oil out. then in the morning i put in 4 qts of castrol 5w-20 and a walmart oil filter. looks like in about a month ill have to change my oil agaain
oh yea i also have that FRAM suredrain thing. on a scale from 1-10 as far as worth the money, id give it a 7. due to the plug design all the oil does not drain out. leaves about 1 cup behind. although it is usefull because the tube prevents the oil from spilling hot oil onto your hands, arms, and garage floor. i use an empty milk or water gallon container to hold the used oil. then when the oil stops draining, i take out the oil plug and drain the remaining oil into a container.
Old Mar 11, 2004
i never really have a problem with the oil getting on my hands. i use a regular latex glove, and oil touching my hand is minimal. even though it is hot, it doesnt burn through the glove. i have a problem w/ the filter though, even though nothing spills on the floor i dont like using the plastic bag. anybody know of a better way to get the oil from the filter??
Old Mar 11, 2004
^^ yea i like the suredrain because i can aim the oil into a container instead of a pan. i dont have one of thoes oil drain catch things with the spout on the side. i also heard that repeated skin exposure to engine oil can lead to cancer....
mattdoc
Mar 14, 2017 12:10 PM
RIPSAW
Nov 6, 2015 04:36 AM
Grey
16
Jan 27, 2002 11:34 PM
supercivic01
South
Nov 30, 2001 11:27 AM
civiccowboy
Nov 19, 2001 03:44 PM
