PDA
View Full Version : General Honda Civic Forum Archive.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 [54] 55 56 57 58 59
  1. i dont see a resonator??
  2. What oil do you guys use .HELP
  3. Integra Type-R Swaybars
  4. Need Help Relocating My Spare Tire.. . .
  5. Someone with swapping experience please help!! (Not for 2k1 Civic)
  6. Someone with swapping experience please help!! (Not for 2k1 civic)
  7. MY DIY painting of ACTUAL VALVE COVER
  8. Help w/ removing Bumber for headlight clearing
  9. Any problem with Front Strut Bar?
  10. 2002 Sedan Rear Speaker Install
  11. cleaning injen CAI air filter
  12. What Tire Pressure?
  13. Installing volt meter
  14. rear section exhausts....
  15. Installing Shift Knobs
  16. Installing Locking Lug Nuts?
  17. LED's
  18. Does REAR STRUT BAR do any good to your car?
  19. is this our car?
  20. Custom Airbox.
  21. 2 things..paint code, and where to get
  22. Switches
  23. Anyone had probs getting an alignment? *please read*
  24. Useless piece of metal?
  25. Touching up Paint chips
  26. remove resonator.. yai or nai?
  27. Ground Control DIY Article
  28. Scuff marks on my interior door panels
  29. taking off the glove box
  30. please check my tire numbers fast !
  31. How much is it gonna cost me?
  32. o2 sensor
  33. who has H&R sports?
  34. Do new rims=need for alignment?
  35. HELP Removing Steering Wheel?
  36. Ok...how to install hood pins?
  37. need help on cam gear
  38. need help installing air/fuel meter
  39. Did you have to modify your front perch when installing Ground Control Coilovers?
  40. Nitrous Application Questions
  41. possible newb question, be warned...
  42. Will This Work?
  43. Differing results with eibach pro?? Poll..
  44. WHat is the difference between the EX and the 1.7i ES model?
  45. HOW DO YOU TAKE OUT A/C VENTS?
  46. Whirring Noise from car
  47. Going dual exhaust!!!!
  48. Front Upper Strut Installing?
  49. gotta small problem. i hope.
  50. Air bags
  51. Guys, How low can a 2k1 civic with a body kit go?
  52. thinking about taking out back seat....
  53. Aftermarket battery helping pulley woes?
  54. Where to buy dampers?
  55. Magnaflow DIY???
  56. a brake question???
  57. How to adjust Ground Control coilovers?????
  58. Transmission gearing..change?
  59. What is delta pressure?
  60. injen sri install????
  61. Front Bumper Question
  62. Exhaust Hitting Bumper...........
  63. Experts only!!!....
  64. what size screw would you recommend for securing mesh to my new xenon bumper?
  65. HID LIGHTS
  66. O2 sensor locations (HX vs others) PICs
  67. Searching Threads and came across......AzNMan
  68. [ Differential ]
  69. Install lowering springs first or strut bar?
  70. LED's for 7440 Rear Turning Signal
  71. read too many threads, still not entirely sure what to do....
  72. 17's and ECU??
  73. Kaminari kit QUESTION!!
  74. cold air Intake... short ram air intake... teach me!
  75. Am I Ruining my car by.......
  76. problem with my sri installation
  77. Lowering with Octane?
  78. I NEED HELP!!!!!!!
  79. cat back exhaust price
  80. DIY Reverse Indiglo Gauges (with pics! again)
  81. Backfiring Already?
  82. OEM fog lights - light pattern
  83. Ping/clank Noise. Annoyed. Help Please.
  84. Couple questions regarding lowering the 2001
  85. Lowered Ride... Rougher Ride?
  86. Does This Shoe Make Me Look Fat?
  87. ENGINE WEIGHT????
  88. ATTN: DIY pulleys; people whu did it
  89. DIY tachometer Help?
  90. Automatic Tranny Problem
  91. OBX Exhaust Prob.....
  92. Rear Window defroster sucks
  93. throttle cable for 5speeds
  94. Help with Street Glow Gold series......
  95. Need info on LED size
  96. how to install racing seat brackets?
  97. my new carbon fiber hood doesnt latch into place
  98. Grillcraft lower bumper grill kit........
  99. i need help
  100. vinyl interior
  101. Suicide Doors
  102. OBX Exhaust Sys....
  103. REAR TINT & DEFROSTER
  104. Cai rubbing on hood
  105. Varad LED scanner
  106. Air Ride and 01EXtc
  107. DC Sports TCS
  108. anyone tried painting the fabric?
  109. A Question for u Tech Wizards
  110. Neuspeed upper front strut bar install...
  111. Co2 Cooling System *NEW IDEA*
  112. What is purging
  113. 2 NItrous questions
  114. LED lights?
  115. how do i remove my dash?
  116. body roll & strut bar?
  117. Thermal Dynamics...
  118. Is there a DIY for pulley installation?
  119. CO2 in intake
  120. how do projectors work?
  121. Adding Daylight Running Lights
  122. N2O question looking cool
  123. MOUNTS???
  124. to purge or not to purge
  125. Door panel removal?
  126. How much HP gain from CAI & Exhaust??
  127. TIMING GEAR???
  128. looking for bulb and help
  129. losing performance
  130. Can't slam our car!!!!!
  131. installing bypass valve for injen cai
  132. turn signal bulb
  133. FOG LIGHT/DRIVING LIGHT QUESTIONS
  134. Throttle cable DIY
  135. Throttle cable problem
  136. DX TO LX GAUGE CLUSTER WORKS
  137. screws attached to radio
  138. Back up for the AEM sri DIY install?
  139. Replace HORN....
  140. TORQUE SPEC on BOLTS!?!
  141. I NEED HELP!! Something went wrong
  142. Urgent:Done with DIY Headlight, Sealant extra
  143. What is the offset for H&R 1.3" dropped. 215/45/17 ?
  144. DIY White Gauges -- part 4?
  145. Guage Question, not indiglo or EL
  146. Vtec conversition
  147. Clearing Headlights on a 98/99 Civ
  148. interior painting...
  149. Mylar..Info
  150. DIY : groundcontrol coils install
  151. full throttle sensor
  152. DIY: Painting inserts??
  153. hiding neons??/
  154. DIY TRUNK?
  155. Goin To Honda Friday for info on dash lights
  156. rear emblem question
  157. Where to put this?
  158. DIY Center and Rear Console
  159. Going to attempt to clear headlights
  160. Hey Grey, quick question about ur brembo.
  161. Remeber lowonairs trick hood?
  162. Question for anyone with aftermarket seats
  163. CLEARING CORNER LENSES
  164. To camber correct or not to camber correct.
  165. Gull-wing doors on 2K1
  166. Honda doesn't sell just gauges..
  167. Should i get dual exhaust or kit first?
  168. catalyctic converter
  169. Painting tail lights
  170. ADJUST THROTTLE WORTH IT???
  171. NEED HELP INSTALLIN PEDALS
  172. post-brake job probs
  173. How the hell do you take off the shift knob??!!
  174. APC 7443 LED BULBS
  175. Installing LED Washers
  176. Maint Reqd
  177. Stick Shift
  178. INTAKE HOOK UP
  179. 10W20
  180. Lock Nuts/Alarms Etc.
  181. About to clear my headlights...
  182. Installed Injen CAI, Now Headlights Broke?
  183. Engine question...
  184. K&N filter part number
  185. Mods that void warranty?
  186. How do i take out my headlight bulbs..please help
  187. lowered 1.5
  188. Question about spring install (tie rod removal)
  189. Need a definative answer...
  190. under steering column wires
  191. Heated Side Mirrors
  192. Raising a car after lowering it???
  193. check my numbers please ?
  194. Car won't idle!
  195. hehe,WHOOPS
  196. Koni front strut measurement
  197. Anybody lower their car 3" ?
  198. installing kaminari kit
  199. More power w/o the turbo
  200. SRI question...
  201. H&R Spring ... Need Help!
  202. Need Help with Tail lights..
  203. Need Help with Tail lights..
  204. coilovers, struts, sway bars, ............
  205. Blown Shocks: Front or Rear Usually?
  206. How A VTEC works /w pics
  207. engine swap for 2001 automatic ex coupe
  208. How did you keep your grill on?
  209. DIY White Gauges, Part III -- Installed
  210. Neuspeed Sport Springs...
  211. is installing tail lights ez?
  212. HELP! i'm doing the front springs, and the tie rod
  213. Tinting
  214. Fuel system?
  215. How to "shave" LX emblem
  216. Does anyone know the torque #'s?
  217. how much for dent removing
  218. wheel sizing
  219. Wheel Gap
  220. any1 know how to remove dings
  221. Quick question before DIY...
  222. Relocate cd player to cig lighter area..
  223. Help me with my tachometer please, 3/4 wires done...
  224. odometer/mileage...
  225. Where did you mount your indiglo switch?
  226. DIY White Gauges -- part II
  227. CAI installation question
  228. Injen CAI, straching
  229. 10,000 mile check light???
  230. Is spring compressor necessary???
  231. I KNOW ive seen this on this site!!
  232. How do you change the 7443 bulbs? (front turn signal)
  233. R Dropzone Springs any good?
  234. how much for those camber kit install??
  235. Need a cheap solution to prevent my trunk from *almost* killing anymore people :)
  236. When to have an alignment
  237. sound from Fast and Furious!
  238. New Euros stick out a little
  239. whats up with projectors.. they dont seem balanced?
  240. i forgot how much oil we put in
  241. how do i get through firewall??
  242. Springs arrived.. few quick Q's so i don't screw my car up :)
  243. Mesh Grille
  244. i really need help
  245. diy spring
  246. DIY Custom Gauges... coming soon!
  247. greeted by the maint required flashing light
  248. When to change oil?
  249. Recommended 5W20 Oil?
  250. Returnless Fuel..Getting somewhere
