how do i get through firewall??
Old Mar 22, 2002
Neofusion's Avatar
Neofusion is an unknown quantity at this point
could someone please explain to me how to run some wires through the firewall?? im trying to wire my neons to the battery.. i know how to do everything except get through the firewall[IMG]i/expressions/face-icon-small-disgusted.gif[/IMG].... anyone??
thanks in advance
-Neofusion
Old Mar 22, 2002
Duckor's Avatar
Duckor is an unknown quantity at this point
I had a problem reaching my firewall hole (on right side on passenger side). So i went thru the door instead, works just as well. Theres a little hole under the hood that is right next to the driverside door, i ran a wire thru it and it came out the hole where the door hinge thingy is and i ran it under the plastic behind the little holder that i keep my change in.
Old Mar 22, 2002
eProdigy's Avatar
eProdigy is an unknown quantity at this point
if youve got a manual it is tought, but i managed to find a small hole on the drivers side. if you open the hood and look back right where the steering wheel is, you will see this single red wire that goes through the firewall. take a coat hanger and poke a hole in the rubber that holes the wire in place and it works like a charm.
Old Mar 22, 2002
iamboo's Avatar
Retired - SoCal FI Mod
i couldn't find the firewall so i drilled my own..[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old Mar 22, 2002
djlunatic's Avatar
djlunatic is an unknown quantity at this point
"I had a problem reaching my firewall hole (on right side on passenger side). So i went thru the door instead, works just as well. Theres a little hole under the hood that is right next to the driverside door, i ran a wire thru it and it came out the hole where the door hinge thingy is and i ran it under the plastic behind the little holder that i keep my change in. "
i did that also but changed the wiring to through the firewall. in time i noticed the rubber weather seal wasn't as tight. and the plastic you pass through warps. the biggest reason was the constant sound of the doorwistling, like its open because of the warped weather seal.
i didn't help that i used 4 gauge wire.
you can run through the firewall hole. its a little trickey, but not unreasonable. it looks cleaner and keep road noise to a minimum
Old Mar 22, 2002
zero's Avatar
zero is an unknown quantity at this point
There should already be wires running inside your car from stock wires. Just use a knife and cut along side of the rubber housing and run your wires next to the stock wires. safest way to do it. Don't drill any holes like the other guy, you might cause your car to catch fire.
Old Mar 22, 2002
01Ex's Avatar
01Ex is an unknown quantity at this point
Just Drill a hole. Its easy and cleaner.
Old Mar 22, 2002
Intruder's Avatar
Intruder is an unknown quantity at this point
Old Mar 22, 2002
Mokushi's Avatar
Mokushi is an unknown quantity at this point
Intruder, where does that come out on the inside? Do I need to take the glove box off to do that? I'm curious too because I'm wiring my neons tomorrow...
Old Mar 23, 2002
CoupeStylz's Avatar
Si(R) killer # 1
CoupeStylz is an unknown quantity at this point
It's really easy guys. get inside your car and peel back the carpeting on the upper left side of the passenger floor sorta behind the stereo. There is a rubber grommet with wires already running through, and room for several more.
03RedCivic
Aug 15, 2003 10:47 PM
komodomichie
Jul 11, 2003 09:12 PM
